DIY underdrive pulley install | Victory Motorcycles: Motorcycle Forums
Discussion in 'Tech Q&A' started by Trappedinchitown, Feb 2, 2021.
  1. Trappedinchitown
    Trappedinchitown Active Member
    Jan 8, 2020
    145
    52
    Victory Hammer
    Has anyone done their own underdrive pulley install?
    Anything I should be made aware of?
    Anyone feel it wasn't worth doing themselves?
    I did the cam and torque tubes install last year on my 2011 hammer, it wasn't easy but wasn't awful either.
    I called a local dealer and they'd charge $250 and id have to trailer it about 1.5 hours to get it done or I can just do it myself.
    Leaning at doing it myself but just making sure I'm not going to deeply regret it lol.
    Thanks in advance.
  2. Kinger08
    Kinger08 Member
    Sep 20, 2019
    82
    14
    2008 kingpin
    Following
  3. IM12STPN
    IM12STPN Well-Known Member
    Nov 1, 2014
    12,066
    6,961
    Houghton Lake, MI
    2016 Vegas 8-Ball BLACK!! 2016 CCT...BLACK also
    From what I've heard getting exhaust out of the way to worst of the project.:bandit: BUT WORTH IT!!:dance: (First new part ordered for new CCT....oops, AFTER CAMS:icon_thumleft:)
  4. wvrider1
    wvrider1 Well-Known Member
    May 20, 2012
    3,624
    1,138
    WV Appalachia
    Goldmist/Black 14 XCT
    If you can turn a wrench, not hard. Have new exhaust gaskets. Soak the exhaust nuts a day before you start. Torque is 180 on the nut. Not all 1/2" TW go that high. I pulled the timing cover and locked the crank. There are other methods. People use impacts, I used a breaker bar because I didn't want the hammering on the trans. Wait until your done to have that celebratory brewski.
  5. BP6666VR
    BP6666VR Well-Known Member
    Dec 23, 2013
    3,705
    1,541
    World Citizen
    I did it myself, it's fun to do,
  6. PreachSF
    PreachSF Well-Known Member
    Dec 3, 2012
    1,635
    1,062
    Delray Beach, FL
    biggest tip .... the stock pulley nut is held on with red locktite. use a torch and heat that thing up before you try to remove it and it will come off much easier. especially if you have an impact with a 1 & 7/8 socket (BIG f**ker)
    • Informative Informative x 2
    • Useful Useful x 2
    • Winner Winner x 1
  7. Trappedinchitown
    Jan 8, 2020
    145
    52
    Victory Hammer
    I'll need a trip to harbor freight for that size lol
  8. slickvic
    slickvic Well-Known Member
    Dec 22, 2011
    10,829
    4,516
    South Florida
    2011 Cross Country
    They
    HF does have a new tool line ..... Icon.
    looks decent quality. Lifetime warranty. Not cheap either. Yes pulley is doable with right tools and know how. Just have to know how. @PreachSF has best advice yet. Take it ..... after all they make the pulley !!
    • Agree Agree x 3
  9. walks35
    walks35 Well-Known Member
    Sep 18, 2009
    897
    489
    NW Burbs of Chicago
    2004 Victory Kingpin
    No more free HF flashlights damnit!
    • Funny Funny x 1
  10. wayne guess
    wayne guess New Member
    Jan 15, 2017
    14
    10
    bridgeport ,Al.
    victory,victory,victory,triumph ,hd
    i did a overdrive pulley on my 2001 several years ago , that was pretty simple , should be the same
  11. primethious
    primethious Well-Known Member
    Aug 14, 2013
    7,970
    2,424
    2012 Victory Cross Roads
    After you get the bolt out of it make sure you use some brake cleaner and a right angle pick to clean all the threads before assymbly. Never hurts to run the bolt all the way in the cleaned threads once with just your fingers. Any resistance means more cleaning.
    It's been a while since I did mine, but I think I used a specific sized drift to lock up the transmission before removal(May have been when I dd the clutch...). Don't want to hurt the trans gears.
  12. 53canuck
    53canuck Well-Known Member
    May 25, 2013
    1,773
    696
    Left Coast, Canada
    2011 KP
    It's an expensive socket for limited use. Especially in mm for those in the USA. Try to find a friend of a friend who's a heavy duty mechanic to try and borrow one.
  13. Craig S
    Craig S Member
    Jan 7, 2017
    35
    20
    Millersburg, Oregon
    2012 XC HB
    Exhaust was a c-word. Lots of penetrant and patience on the studs. Would hate to break those off. Tape off the fins on the heads/cylinders so you don't beat them up getting the headers off/on. I used blue masking tape. The big nut was interesting. Impact ended up making the job easy. After getting that big old nut back on take it easy on the small bolts holding the lock plate in place, easy to over tighten them. Your gonna love the pulley, maybe my favorite mod. Cams are right up there too. Have fun!
    • Like Like x 3
  14. Trappedinchitown
    Jan 8, 2020
    145
    52
    Victory Hammer
    Thanks! This was helpful and encouraging.
    I'm getting excited to feel the difference the pulley brings.
    • Winner Winner x 1
  15. jellybean764
    jellybean764 Active Member
    Oct 21, 2012
    934
    127
    Arnprior
    Victory2013 Boardwalk 01 Buell Cyclone
    The exhaust is the worst part of the job.I used a piece of wood about 1/2 by 1and 1/2 by 4 inches long I put between a tooth on the sprocket and the swingarm to keep it from turning when I loosened and tightened the big nut.As been previously mentioned use a bit of heat on the nut first to soften up the loctite.It might be a good idea to put a bit of lube on the splines before you put the new pulley on.Splines have more of a tendency to wear if dry.
2016 victory magnum underdrive pulley install
