Custom Billet shift linkage by CycleOpsUSA! | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory General Discussion' started by bikendad, Dec 13, 2012.
  1. bikendad
    bikendad Well-Known Member
    Apr 10, 2009
    7,013
    1,261
    SE Michigan
    2010 Victory Cross Country
    Just got this in the mail, Santa came early! It's freakin gorgeous, beautiful work Will!!!
    [​IMG]
  2. RoBrown
    RoBrown Well-Known Member
    May 25, 2011
    1,367
    86
    New Philadelphia
    07 Victory Kingpin
    Looks pretty good. You will have to post a pic once you get it mounted. Rob
  3. grounder
    grounder Member
    Oct 20, 2009
    181
    11
    Marquand
    I want one!
  4. bikendad
    Apr 10, 2009
    7,013
    1,261
    SE Michigan
    Here's a little better pic, the chrome on this baby is Sweet!!
    [​IMG]
  5. SLORIDE
    SLORIDE Member
    Oct 1, 2011
    89
    4
    Hot Springs
    2012 Cross Country Tour
    Very nice!
  6. BBob
    BBob Well-Known Member
    Aug 18, 2010
    3,867
    776
    AZ
    11 XC, 04 KP
    Will's parts are first class all the way.
  7. bikendad
    Apr 10, 2009
    7,013
    1,261
    SE Michigan
    Yes they are, his workmanship is at the highest level!
  8. bikendad
    Apr 10, 2009
    7,013
    1,261
    SE Michigan
    OK I finally got around to getting this sweet piece of Bike Jewelry installed, took around 30 minutes plus or minus a few. Here's the final look :)
    [​IMG][​IMG]
  9. bikendad
    Apr 10, 2009
    7,013
    1,261
    SE Michigan
    Just rode it this morning for the first time since doing this mod and I can't believe how much nicer/more positive the bike shifts! Between the much stiffer Billet linkage and the larger Heim joints it makes a noticeable much more positive shifting experience :)
  10. morfoot
    morfoot Member
    May 5, 2012
    153
    11
    McDonough
    2003 "UGA" Vegas, 2013 Cross Country Tour "Cap"
    I sorta, kinda did the same thing with the Vegas only I made mine (with a little help from one of the machinest's I work with in the shop).I scrounged and founda block of T6 aluminum in the scrap metal bin out by the tooling deptthen traced out the lettering that I wanted. I used the bridgeport milling machine to do some of the easymilling then turned it over to my machinest bud to do what he could. He was able to remove allot of the metal but couldn't millout the rest of it with the bits that we had as the lettering was really close together. Brought it homechucked upaDremel tool in a router base and finished the lettering. Took it back to work drilled, threaded and installedthe ends afteracquiring some used rod ends from the shop that replaces tie rod ends.I used a 'Tramel Bar'rigging toolto set the rod ends to exactly matchthe original tie rod installed and after the final adjustments and running down the jam nuts Itook to the paint shop for the black epoxy paint. Final step was to the buffer after the paint driedfor some serious polishing.Got it all shined up as best as I could theninstalled it on my UGA themed Victory. I too noticed a HUGE difference in the way it shifts plus itadds a great look to the bike.I think if you guys splurge for one you won't be disappointed.
    [​IMG]
    [​IMG]
    Before you guys even ask me.....the helmet on the LEFT is mine and the one on the right is for my female riders.[​IMG]
  11. bubba
    bubba Well-Known Member
    Sep 27, 2008
    4,500
    59
    Denver
    2006 Kingpin
    They look great!!!! I have had them on a couple of my bikes. A tad confused on why they would shift better. The only thing I could think of is that they were not adjusted right the first time. NICE BLING!!!!
  12. morfoot
    morfoot Member
    May 5, 2012
    153
    11
    McDonough
    Only thing I can figure as to why it shifts better is that the linkage is beefier and hasZERO flex as comapared to a 3/16"- 1/4 inch rod that comes from the factory.
  13. bubba
    Sep 27, 2008
    4,500
    59
    Denver
    2006 Kingpin
    That works!!!!
  14. bikendad
    Apr 10, 2009
    7,013
    1,261
    SE Michigan
    I agree, the linkage itself is totally rigid and the optional chrome Heim joints are much larger/beefier. When I pull up on that shift lever now it's a very positive feel, I think the stock setup is too flimsy.
  15. Kronker
    Kronker Active Member
    Dec 10, 2012
    236
    84
    Jackson, TN
    2013 Highball
    How long did it take you to receive your linkage? I have had one ordered for a month, and it hasn't shown up yet. Looks llike it's definitely worth the wait!
billet gear shift for victory vision 2013
billet shifter victory
custon shift linkage for victory motorcycle
