Cruise not setting | Victory Motorcycles: Motorcycle Forums
Cruise not setting
Discussion in 'Tech Q&A' started by James2003x, Jun 9, 2021 at 11:59 AM.
  1. James2003x
    James2003x Active Member
    Jun 27, 2019
    188
    67
    Ooltewah, Tennessee
    2015 XCT
    Will the ABS light being on cause the cruise control to not set?
  2. Alwhite00
    Alwhite00 Well-Known Member
    Sep 13, 2020
    397
    274
    Victory
    No. I have a bad abs sensor (I think) with the abs light on and the cruise works fine.
  3. wvrider1
    wvrider1 Well-Known Member
    May 20, 2012
    3,803
    1,201
    WV Appalachia
    Goldmist/Black 14 XCT
    Most common is cables out of adj. Next would be throttle switch. It hides just in back of the tank. Just pull one wire. Do you know how to get it into diagnostic mode.
  4. jmstang302
    jmstang302 Well-Known Member
    Aug 18, 2013
    4,981
    2,063
    Littlestown
    Have you added any lights?
  5. tyrfryr
    tyrfryr Well-Known Member
    Aug 20, 2014
    715
    272
    Nebraska
    Cross Roads Classic
    Is your brake light always on? Brother had a rear brake light switch go bad and had no cruise, could also be front brake light switch or maybe clutch switch. Good luck.
  6. James2003x
    Jun 27, 2019
    188
    67
    Ooltewah, Tennessee
    2015 XCT
    Not my bike.
    nothing recently added
    not sure about the brake light switch
    pink wire already disconnected.
  7. jmstang302
    Aug 18, 2013
    4,981
    2,063
    Littlestown
    Does it power up, the red light is on?
  8. James2003x
    Jun 27, 2019
    188
    67
    Ooltewah, Tennessee
    2015 XCT
    Yes
  9. jmstang302
    Aug 18, 2013
    4,981
    2,063
    Littlestown
    Have you tried to get it diagnostic mode as instructed in Paul's video?
