Cross Country Air shock on a Kingpin | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Kingpin' started by ENGHP, Apr 22, 2021.
  1. ENGHP
    ENGHP New Member
    Dec 8, 2016
    11
    1
    Victory Kingpin
    Anyone installed a Cross Country air shock on their Kingpin? I ride solo and sometimes have a passenger. Spring adjusted for a passenger is to stiff for solo(bad back) Thinking of converting to rear air shock . I don't want to spend big $$$ on the shock. So thinking I will use a take off Cross Country.
  2. tree1979
    tree1979 Well-Known Member
    Jan 10, 2014
    4,222
    1,391
    Birmingham, AL
    2007 Victory Kingpin
    I had one for a while. Fit just fine, but you have to rotate the lower clevis 90 degrees. Will lower the bike, so you'll need a fender liner. You'll need to keep the pressure a lot higher than what is needed on the CC, typically around 40 PSI. Its a better ride, but not nearly as good as the Penske shock.
  3. Bikesofbrads
    May 16, 2020
    2,922
    1,834
    South central/eastern ohio
    2015 victory xct & 06 katana
    40 psi is about the minimum for an xc’s shock or you’ll pop the seal & she’ll start to leak. Has your stock shock ever been serviced? You’d be surprised how much difference it’ll make just adjusting the sag correctly. If ur factory shock is in good condition, no leaks ( pivots / clevises / linkages lubed ) the sag is set correctly for your weight is relatively free. If the compression cannot be adjusted a lil softer & the rebound can’t be slowed down to meet ur comfort needs changing the spring might be a cheaper option. It is possible to find a good, used CC shock but their not that great either. It’s made for a much heavier bike so is much stiffer than what you have now. Have you tried a different seat or an air hawk pad? Between a shock linkage lube / sag set & a good seat pad it may do the trick.
  4. NHKingpin
    NHKingpin Member
    Jun 27, 2016
    85
    86
    New Hampshire
    2004 Victory Kingpin
    I currently running a CC shock in mine last 2 years, not a single issue, single or 2 up. The stock shock has a lot to be desired. Agree the it will lower bike about 1" and definitely run a fender liner if you do the CC shock
  5. Motorbikerx
    Motorbikerx Well-Known Member
    Dec 27, 2013
    1,347
    1,256
    Gold Coast, Australia
    2010 XC 2006 KINGPIN
    Try a Grasshopper backrest, it'll force you to sit up properly, also start doing yoga to strengthen your core muscles, I also got an AirhawkR
    No more sore back...well not much anyway'
    I actually find the stock Kingpin shock with its extra travel not too bad at all
