Hydraulic Clutch - It's a solid shaft coming from the slave. Don't see any adjustment.mjw930 said:I think the hydro clutch uses a cable from the slave that connects to the clutch actuator the same as the normal cable. If that's the case then you should be able to use the clutch assist unless there's not enough adjustment in the short cable stub that is attached to the slave.
