So noticed on the ride home the clutch slipping in 4th gear when under load. Get home start looking around and find the the arm of the gearbox isn't returning to its home position. Once you release the clutch you can move the arm around 5-7mm back to the home position. There seems to be enough cable slack in the system so don't think that is the issue.
I'm on a 2011 Vegas 15xxxkms. Any help would be appreciated.
