1 - 20 of 34 Posts
Damn.. my search continues for those freaking under-the-floorboard-highway pegs. I had my fingers crossed.
How about the JB Hatch pegs? Those are readily available.
First I've heard of them. My issue is the CCT with the hard lowers and wind deflectors etc..etc.. I had aassumed that the only ones would fit would be those "under the floorboard" ones...?
Nope, definitely not the only option. I went with some Kuryakyn highway pegs. I have them positioned where I can have the heel of my foot still on the floorboards while using them. Very comfortable set up.
Reactions: Ghostrider25
About to pull the trigger on the OEM Stage 2 2in1 black exhaust. But curious. How does this compare to aftermarket full exhaust (bassani, TBR, etc)? This is full straight pipes right, no baffles and not a slip on?
Discussion Starter · #13 ·
I have the 2-to-1 pipes on mine, it was pretty easy to add on, although you will need a dyno it after.
Personally I dig the look and the sound. it's deep, a bit loud but not too obnoxious.
https://photos.app.goo.gl/RNuuYKUDuakMEAP56
Administrator
After all this time they still have a lot of stuff, I guess either Polaris way overproduced or the stuff just doesn't sell. Big mark downs for sure.
Got the "USA" emblems and a spare set of backrest/ bag mounting spools. Great find.
Kingsnake did the 2into1 come with instructions at all from Leaders? I'm thinking of going this route but wouldn't mind having a guide. Last time I did an exhaust was a decade ago at this point.
Also, did you get it dynod, or did you go with a power Commander? What's a Dyno run, ballpark? Can any shop do it or does it have to be a Polaris dealer.
Thanks guys
Discussion Starter · #18 ·
Thanks guys
There should be instructions - I can check, I might have kept mine. I also followed this video from Polaris
I had installed a power commander (picked it up off of Revzilla) but haven't had it dyno'd yet. We have a place in the PNW that'll do it, but it's like $400 and takes a bit of time - two things I don't have often!
Great thanks for the info. Fwiw, and I'm not the expert on this. But my understanding has always been, you get the power Commander in leiu of getting a Dyno. As in the do the same thing, but one is user input (PC) vs the other is done by a shop. They are both a remap of the fuel/air ratio. So if you have the PC you may not need the Dyno but don't quote me on it!
Discussion Starter · #20 ·
I ordered the 2:1 exhaust and power commander at the same time so I could just do a full install when I had all of the parts. Since the exhaust needed the dyno I just wanted to kill two birds with one stone. One thing to note, the exhaust should come with a card from Victory with the dyno info. Maybe before ordering you check with them to see if that's the case.
1 - 20 of 34 Posts
