Ok after countless days and nites trying to find the problem I give up! Here's what's happening. 2010 XC, stage 1, LLoyds IAV, gen III, , 25,000 miles, o2 sensors off. I started having the check engine light started coming on, the code states that a circuit is open or there's a short to battery power. Went through all the tests in the service manual and they all passed. I went back through all the tests again after going through all the wiring related to the IAC. found a couple of bad wires, fixed all. Replaced engine relay, IAC, wiring harness and connector for the Iac. problem is still there. haven't gone to dealer because I don't have one anymore(went out of business 2 weeks after I bought it) and I don't want to pay them to trace an electrical problem at $85-$110 hr. I'm at a loss as to what it is. I did go back and did another check of the IAC circuit and everything checks out. While I was doing the voltage tests which says power should be to pins 2, 5 from the 87 terminal of the engine relay I decided to see if power was at any of the other pins at the IAC connector. Pin 3 was the only other one that had power. My ??? can anyone out there do a check of pin 3 on the connector to ground voltage check to see if that's the problem and if so would an ECM reflash be a possible fix??? and yes battery terminals are fine. I'm going to attach the procedure for checking the IAC from the service manual. What ever is causing this is stopping the IAC to fuction, which in turn won't allow the IAV to adjustment.
I hope that someone can do me this favor and maybe even suggest a fix for this, as it's very frustrating having a great bike that I can't ride!!
Thanks
Ken
