Check engine light 2017 XC | Victory Motorcycles: Motorcycle Forums
Discussion in 'Tech Q&A' started by fsbreezy, Oct 1, 2020.
  1. fsbreezy
    fsbreezy Member
    Aug 29, 2013
    31
    13
    Georgia, USA
    2017 Cross Country Tour, 2016 Indian Dark Horse, 2013 Cross Country Tour, 2008 Harley Ultra, 74 shovelhead
    Oh crap! My check engine light on my 2017 XC came on again. When I first got the bike it poped on but the bike was still under warranty and it turned out to be a bad O2 sensor which the dealer replaced. Now its back and the warranty is out. Is there a way to bring up the codes or do I have to have a reader or dealer only fix. What if I replace the senors myself will the light go out or does it have to be reset by the dealer? Thanks, Breezy
  2. NOEMTZ
    NOEMTZ Well-Known Member
    Jun 5, 2008
    1,005
    274
    Waller
    Should be able to turn key and kill switch on, scroll through dash read outs if still an active code.
  3. fsbreezy
    fsbreezy Member
    Aug 29, 2013
    31
    13
    Georgia, USA
    Thanks!
  4. Wild Bill
    Wild Bill Member
    Dec 17, 2019
    68
    24
    Cross Roads
    How would I do it with an XR? Mine just came on, sounds fine.
  5. Bikesofbrads
    Top Poster Of Month
    May 16, 2020
    756
    449
    South eastern ohio
    2015 victory cct & 06 katana
    After restart bike does it come back on, glitches do happen but usually it’s a loose/ dirty battery connection
  6. Wild Bill
    Wild Bill Member
    Dec 17, 2019
    68
    24
    Cross Roads
    I'll check it tomorrow- putting new plugs in and I was in the battery area a few weeks ago!
  7. Bikesofbrads
    Top Poster Of Month
    May 16, 2020
    756
    449
    South eastern ohio
    Re Check the batt connects & load test the batt, if cel stays on U’ll hafta take note of the codes letters / #’s because they will clear once turn key off. Hopefully was a glitch but if not is tons of very knowledgeable people on here that’s already been there & fixed that. Good luck
  8. Wild Bill
    Wild Bill Member
    Dec 17, 2019
    68
    24
    Cross Roads
    It went out, I tightened the battery connections. Hopefully it was a fluke! Thx for the input everyone!
  9. slickvic
    slickvic Well-Known Member
    Dec 22, 2011
    10,378
    4,207
    South Florida
    2011 Cross Country
    Ok tightening the connections are one thing but while your down there. Sand paper or wire brush the posts and the ring terminals goes a long way. Then tighten down with a wrench using a star washer under the bolt. Dab a little dielectric grease on and check every oil change while the bike is draining. This is the best time also to lube you clutch cable pivot points at the barrel ends and the lever. Clean a lube shilft rod ends and lube the pivot area of your shifter and and brake pedals. I won’t tell you what oil to use because you should already know by now.
  10. Motorbikerx
    Motorbikerx Well-Known Member
    Dec 27, 2013
    337
    337
    Gold Coast, Australia
    Victory Vegas Low 2010
    my XC will light up the Check Engine light sometimes when engine braking down a steep hill in third gear, I reckon its the O2's throwing it cos its going a tad lean.....Its been Maximus Dyno tuned, only ever does it occasionally and an upshift to 4th puts it out again.
    I'm not concerned but just thought Id mention it.
    Could disconnect the O2's I guess as it was tuned with them unplugged
  11. Bikesofbrads
    Top Poster Of Month
    May 16, 2020
    756
    449
    South eastern ohio
    @Motorbikerx The gurus say to leave O2’s plugged in with Maximus, was tuned with wideband O2’s then they switched back to our factories after the tune. Is odd though how it only does it when engine braking n 3rd & goes out when ya hit 4th. Ur prob right about it temporarily goin lean under hard decel as engine speeds still high & very lil fuels going in.
  12. Wild Bill
    Wild Bill Member
    Dec 17, 2019
    68
    24
    Cross Roads
    The initial issue was that is was revving low and stalled while in a turn- I was able to fire her back up with no problem but had to keep revving it during the short ride home. It was fine the next day until the cel came on. I did the IAC reset- as I did a month or so ago. Is there something getting ready to cost me money!?
  13. Bikesofbrads
    Top Poster Of Month
    May 16, 2020
    756
    449
    South eastern ohio
    @Wild Bill Have u checked ur air filter lately or maybe just got less than stellar gas
  14. Wild Bill
    Wild Bill Member
    Dec 17, 2019
    68
    24
    Cross Roads
    Probably time to look at it, I just got it back in February with 18k on it...at 25 now. I guess it's at stage 1, has the tri ovals!
  15. Wild Bill
    Wild Bill Member
    Dec 17, 2019
    68
    24
    Cross Roads
    Is the performance air filter a rechargeable one or does it need to be replaced?
    I have k&n oil.
