Good Morning,
Bike started running super rough, check engine light came on and got code '102 4'.
replaced original battery with new battery, verified all battery cable connections are tight.
started bike up, idle is terrible, check engine light comes on again with same code '102 4'.
Looks like it may be an issue with the MAP sensor? Has anyone encountered this and what was your solution if so?
Thanks for any guidance.
EDIT : http://s3.amazonaws.com/mixmobi_images/assets/18989/document.pdf?1380056740
This is the definition of the Indian Check Engine codes, appears to also match the codes for Victory bikes.
