Can't loosen the screw holding on rear fender | Victory Motorcycles: Motorcycle Forums
Discussion in 'Other Victory Models' started by oldroadrunner, May 3, 2021.
  1. oldroadrunner
    oldroadrunner Member
    Feb 11, 2021
    99
    66
    Emerald Isle NC
    Betewen cities and states
    2002 V92C Deluxe
    I am trying hard to loosen the allen head (5mm) that holds on the fender.
    It seems ungodly tight.
    My next move will be to go buy some sockets for my electric impact wrench.
    But, before I bring out that sledge hammer, I wonder if there is something I am missing about this task?
    So far... several sprits of wd-40, during an hour.
    So far... I used the water pipe on the end of the allen wrench and there is enough force to put a bow in the wrench (which I could not do by hand) and at that point I said to myself... wtf... might as well ask the forum.
  2. lou8700
    lou8700 Well-Known Member
    Dec 3, 2012
    5,457
    2,675
    St. Louis
  3. VicVisionBulldog
    Top Poster Of Month
    Mar 27, 2011
    21,017
    9,429
    Houston
    Goodness!
    I would try an impact.
  4. oldroadrunner
    Feb 11, 2021
    99
    66
    Emerald Isle NC
    Well, I wondered if others had an issue with it.
    I kinda had a plan B.
    And yet, as goofy as things sometimes are, I thought that there might be the slightest chance for advice something like 'grind off a spot weld, or, hey dummy, you do not need to take those off!
    lou87, I DO have a similar Impact.
    Nevertheless... I ordered a $15 set of allen head sockets ... size 2-14mm... on amazon.
    They will be here May 6 they say.
    Not only do I have the impact that you hit with a hammer, but also this one from Harbor freight which I got a few years ago. $60 regular price... but they OFTEN run a coupon $39.
    This thing spins off the drive sprocket nuts, axel bolts, brake disc, stuff like that. It has been a lifesaver. It is big, bulky, needs a cord, does not fit in tight spaces, and still when you need to take the pullies off a car or bike it is a great investment.
    I use a wrench to re-assemble, there is no control for ft lbs.
  5. VicVisionBulldog
    Top Poster Of Month
    Mar 27, 2011
    21,017
    9,429
    Houston
    I have Porter Cable power tool. For Christmas one year my brother bought me the impact. I had the impact driver but not the real impact. I LOVE that thing!!! He bought me two sets of sockets too. Good gift.
    My wife called one day with a flat so I drove to her to fix. Before leaving the house I thought, "take your impact." I felt like a Nascar pit crew.
    Only once did it not have the juice to break a bolt loose, an big old rusted on bolt on my Jeep's bumper. But my breaker bar and my muscle got it loose. Other than that it has been a lifesaver.
  6. Motorbikerx
    Motorbikerx Well-Known Member
    Dec 27, 2013
    827
    739
    Gold Coast, Australia
    2010 XC
    Whack the head of tight bolts with a hammer ...that helps.
    I use Eucalyptus oil on tight threads and to free up time seized old engines, works a treat.
    Or if ya can't get Eucalyptus oil mix half and half Auto trand fluid and Acetone...don't get it on paint.
    Good Luck
    Don't round out the Allen bolt whatever you do.
    Patience grasshopper
    • Like Like x 3
  7. VicVisionBulldog
    Top Poster Of Month
    Mar 27, 2011
    21,017
    9,429
    Houston
    Been there, drilled that. :doh:
    • Funny Funny x 1
  8. oldroadrunner
    Feb 11, 2021
    99
    66
    Emerald Isle NC
    Me?.... Hammer?....Shiny Fender? hahahahahahaha
    But.... if plan B - impact wrench and blaster - does not work, I will patiently use my %^&%$# hammer on it! hahaha
    • Funny Funny x 1
  9. BP6666VR
    BP6666VR Well-Known Member
    Dec 23, 2013
    3,855
    1,595
    World Citizen
    Left hand drills
    • Funny Funny x 1
  10. Chattanooga_Mark
    Dec 25, 2009
    4,668
    1,928
    Chattanooga
    2012 CCT, Wonderful in white
    Is that a 5mm or a 6mm Allen bolt? Either way, a strong impact could easily strip it out. Perhaps a hammer screw gun would be better than an impact on that small of an Allen bolt. That pipe on a single Allen wrench has a lot of torque. Just for grins, verify there’s not a nut on the inside. Let it sit overnight after a few coats with a good penetrating oil as that should help as well. Once it’s out, use anti-seize on its replacement.
  11. Motorbikerx
    Dec 27, 2013
    827
    739
    2010 XC
    Or just leave the fender on..
    Why are you trying to remove it?
  12. wvrider1
    wvrider1 Well-Known Member
    May 20, 2012
    3,744
    1,179
    WV Appalachia
    Goldmist/Black 14 XCT
    Can you get heat on the inside where the nut is. Propane torch?? Try two ball peens, one big, one small. Put the small round head on the bolt head and hit it with the other. Couple good solid whack. Sometimes that helps loosen them up.
  13. Bikesofbrads
    May 16, 2020
    1,804
    999
    South eastern ohio
    2015 victory xct & 06 katana
    Clean the bolt threads from behind the fender, pb blaster it & use lil heat and if you can put a wrench on the nut from the inside? Is usually easier to remove the nut than to unscrew the bolt when it lives in dirty places ( shorter distance )
