Cams & Clutches? | Victory Motorcycles: Motorcycle Forums
Cams & Clutches?
Discussion in 'Victory General Discussion' started by Hsns, Jun 29, 2017.
  1. Hsns
    Hsns Active Member
    May 19, 2015
    111
    31
    Stephens City, VA
    2006 Hammer
    I'm trying to do my homework before I, hopefully, get around to doing cams this winter...
    I have read several posts where people say the stock clutch is barely capable of holding the bikes' stock power and I see many signatures that show upgraded/modified clutches. I also have read a lot of threads on cams where there is no mention of upgrading the clutch and the owners have been very pleased with the outcome. I have a 06 Hammer and I don't currently have plans of venturing into the world of big bores or strokers. What are your experiences of running cams with the stock clutch and what upgraded parts (and preferred brands) are recommended or needed.
    Thanks,
    Hans
  2. NY mike
    NY mike Well-Known Member
    May 15, 2016
    3,103
    2,567
    Goodyear Arizona
    Indian chieftain - Harley Ultra
    I for one will not venture into this with you due to lack of enuff knowledge. But @Half_Crazy and a few others have tons of knowledge with this stuff now hold on because once this thread gets going you'll be shaking your head lol
  3. lou8700
    lou8700 Well-Known Member
    Dec 3, 2012
    5,892
    3,038
    St. Louis
    I think the stock clutch is capable of holding up to around 130 HP / torque if ridden correctly especially on a lighter bike like yours. JMHO
  4. vision_nut
    Aug 15, 2011
    7,876
    747
    vision 08
    wait till you get cams and then go from there. Who ever does the tune are your motor will be able to tell if you need a clutch.
  5. primethious
    primethious Well-Known Member
    Aug 14, 2013
    8,045
    2,479
    I upgraded my clutch without ever having an issue with it. I did it for peace of mind. What causes more clutches to become damaged are two things.
    1. The clutch cable ends aren't kept clean, greased, and adjusted while cold with the proper amount of free play in the cable.
    2. Vision's hydraulic clutches have been known to occasionally allow the plates to slip while riding down the highway. Temp fix was to flick or feather the lever once and keep riding.
  6. NY mike
    May 15, 2016
    3,103
    2,567
    Goodyear Arizona
    @primethious i run these like my Harley's about 1/4 to 1/2" free play at lever to much to little or what ?
  7. Hsns
    Hsns Active Member
    May 19, 2015
    111
    31
    Stephens City, VA
    2006 Hammer
    Thank you for all the replies. This is the consensus I was hoping for.
  8. Half_Crazy
    Half_Crazy Well-Known Member
    Aug 23, 2008
    23,431
    9,547
    Great Mills, MD
    Bikeless
    I wouldn't say that too loudly. The stock clutch barely takes drop-in cams.
    • Disagree Disagree x 1
  9. Half_Crazy
    Aug 23, 2008
    23,431
    9,547
    Great Mills, MD
    Bikeless
    too much.
  10. NY mike
    May 15, 2016
    3,103
    2,567
    Goodyear Arizona
    @Half_Crazy ok help me out here what's the magic #
  11. Half_Crazy
    Aug 23, 2008
    23,431
    9,547
    Great Mills, MD
    Bikeless
  12. Half_Crazy
    Aug 23, 2008
    23,431
    9,547
    Great Mills, MD
    Bikeless
    There isn't one. Either it will or it won't. Once most people venture into cams they get a stiffer clutch spring just for GP.
  13. Half_Crazy
    Aug 23, 2008
    23,431
    9,547
    Great Mills, MD
    Bikeless
    All I have in mine is a beefier spring/pressure-plate and a primary support plate on the outside. Stock clutch pack w/over 100K miles on it. Throttle wheelies... no clutch popping needed... clutch is like new.
    There are RELATED THREADS at the bottom of the page. There will be related threads in those threads too. READ.
  14. NY mike
    May 15, 2016
    3,103
    2,567
    Goodyear Arizona
    Gotcha thanks just looked at mine I'm setting about a 1/4 " all good so far but I get the stiffer spring deal makes sense
  15. DSmith
    DSmith Active Member
    Jan 9, 2011
    512
    175
    08 Vision, 13 Vision, 01 V92, 12 Triumph Tiger, 12 Can Am Spyder, 11 Polaris Sportsman 850 EFI, 81 Yamaha Maxum
    Ya, but they are easy and dirt cheap to replace...
