1 - 4 of 4 Posts
Evening Guys,
I've noticed I've got a scraping sound from my front brake on my 2017 Highball and the pads are worn down alot and i've only done 1600 miles...
I've taken the bike to work and checked the disc with a laser and used the airline to make sure no stones are trapped etc..
It's going back to the dealer tomorrow and they are going to have a look.
I just wondered if anyone else has this issue?
I have 24k on my Vegas and still have not changed pads , front or rear.
Check to make sure that there isn't to much fluid in the master cylinder.
cheers buddy
I've decided not to touch anything as it's still under warranty so i'll let the dealer look tomorrow but I'm not paying for another set of pad when it's only done 1600 miles...
The pads themselves are a wear item so they aren't normally under warranty.
If a caliper is seizing up then they could change that.
I changed my pads while they were still good just to get better ones.
If you change them consider Lyndall Gold plus pads.
1 - 4 of 4 Posts
