I want to bleed my brakes, before I add fluid, the manual says DOT 4 and not to mix with silicone based fluids. Is non silicone DOT4 fluid only available at motorcycle shops? Auto part stores dont carry it.
Thats weird because DOT3 & DOT4 are the most commonly available brake fluids around. Try a Walmart. Make sure it says glycol based...not silicone. Until recently I thought all DOT4 is glycol based but apparently if the bottle says synthetic it has silicone in itI want to bleed my brakes, before I add fluid, the manual says DOT 4 and not to mix with silicone based fluids. Is non silicone DOT4 fluid only available at motorcycle shops? Auto part stores dont carry it.
http://m.autozone.com/brake-and-pow...z-dot-3-and-4-brake-fluid/33406_0_0?location=I'll have to go back and see if AutoZone has non silicone 3-4. Thanks for the help
