I'm installing them now. Easy install but I do have a question.
In the bag of screws there are two aluminum "spacers" about 1/2 inch thick. Each spacer has two holes drilled in it and the instructions show it being placed between the bracket on the rail and the bracket on the muffler. Then a screw plate is placed behind the bracket on the muffler and two screws are run thru the bracket on the rail, the spacer, and the bracket on the muffler and screwed into that screw plate.
Here's the question: Is that aluminum spacer even needed? If I use the spacer then the screws aren't long enough to screw into the screw plate that is behind the muffler bracket.
Thanks for any help.
