So, my clutch was slipping noticeably in 3rd on up. Been using Shell Rotella T6 on the bike, which I have used on many other bikes. I had a choice, go with just the Barnett Billet pressure plate or change the entire pack. I decided to do the entire pack since upon purchase I wasn't positive of the condition of the friction plates so I bought the Barnett replacement pack AND the Billet pressure plate.
Installation went uneventful. I recognized through research and manual that the steel plate machine edge faced upward and friction plate machined edge faced inward. Not abnormal as I have done other bikes that have similar notes. Done.
Took a bit to find a good place for the cable adjustment and I know it will change quite a bit for a few hundred miles. Hard to impossible to get end play while maintaining release but I'm as close as I'm gonna get.
My problem is, now that I have this pack installed, in particular in 1st gear, say parking lot type speed where you're slow riding the clutch, when I have the clutch pulled in entirely it's quiet, but let the clutch out just a smidge and it sounds like a rattle can in that area. It's really only happening with bike in motion though. I can sit there at rest and it's quiet when doing the same thing, but at slow speed it's noisy as f**k. First time I heard it I thought I wasn't entirely in gear because I could not just hear it, I could feel it.
I opened it back up and double/triple checked it all. Did not remove the basket, just picked the plates out, judder spring is installed correctly (didn't remove it the first go since it wasn't in the plan to change it) but I checked it to be sure it was placed properly.
I've done a few searches and it seems that because of the gear drive and that torque compensator this is normal? Question is, I have never heard that before so why now?
It makes me nervous when I hear it because I certainly don't wanna have to start dealing with gearing as it's a lot more involved than merely clutch plates. Just looking for ideas or maybe assurances. Thanks in advance.
