Average???? | Victory Motorcycles: Motorcycle Forums
Average????
Discussion in 'Victory Cross Country' started by Bikesofbrads, Apr 25, 2021.
  1. Bikesofbrads
    May 16, 2020
    1,980
    1,123
    South central/eastern ohio
    2015 victory xct & 06 katana
    Anyone know what body weight Polaris called average for setting up their factory suspension on an 15 xct? My OCD / ADD’s not letting me just choose a different weight / level fork oil without knowing their ideal persons weight spec. Thanks guys, go ride
  2. md2420
    md2420 Well-Known Member
    May 10, 2016
    2,130
    924
    Chandler, AZ
    2014 Vision
    I think they went by Harleys avg for their riders....5’6” and 225lbs. Hahahaha! I kid, I kid!
    • Funny Funny x 7
  3. normthenomad
    May 19, 2018
    598
    310
    Work backward from GVWR in the manual.
    You may be a little low on the H-D weight. (Snark).
    • Funny Funny x 2
  4. primethious
    primethious Well-Known Member
    Aug 14, 2013
    7,993
    2,436
    2012 Victory Cross Roads
    Just set it to what feels good for you. Who cares what they they set it for as if much thought went into it anyway. Suspension is where most manufacturers cut corners for cost savings.
  5. Bikesofbrads
    May 16, 2020
    1,980
    1,123
    The plan is to set up best for myself and the more ya know the better you can adapt, besides I’m stuck at work babysitting grown up’s so I gotta lil time to wonder about those things hahaha.
  6. Blowndodge
    Blowndodge Well-Known Member
    Jan 31, 2013
    2,143
    710
    Utah
    2013 Victory XCT
    How many miles do you have on the air in your tires? Could be time to change it and the air in your shock!
    • Funny Funny x 1
  7. Bikesofbrads
    May 16, 2020
    1,980
    1,123
    I just replaced the winter air with newly filtered summer air, changed my blinker fluid & recalibrated the flux capacitor for the humidity.
    • Funny Funny x 3
    • Winner Winner x 1
  8. Motorbikerx
    Motorbikerx Well-Known Member
    Dec 27, 2013
    917
    804
    Gold Coast, Australia
    2010 XC
    Like to buy a can of tail wind?
    • Funny Funny x 5
  9. Chattanooga_Mark
    Dec 25, 2009
    4,795
    2,013
    Chattanooga
    2012 CCT, Wonderful in white
    Check your front piston return spring, lube the muffler bearings and you may be good for the season. From everything I’ve read, the rear piston return spring is heavier duty and ‘lubricated for life’.
    • Funny Funny x 2
  10. Chattanooga_Mark
    Dec 25, 2009
    4,795
    2,013
    Chattanooga
    I’ve seen cans of tail wind going for crazy money on BringaTrailer.com. Don’t sell it too low in today’s market. BaT seems to get the heavy hitters as far as prices paid are concerned. All the best to you with the sale.
    • Funny Funny x 1
  11. Motorbikerx
    Dec 27, 2013
    917
    804
    2010 XC
    Very true! .... but with the price of gas nowadays its not hard to recoup the cost of even a coupla cans of tail wind (Strong variety is better) over a months riding, specially in hilly country!
  12. jmstang302
    jmstang302 Well-Known Member
    Aug 18, 2013
    4,981
    2,063
    Littlestown
    Seams everyone had a good weekend and nothing to do on this Monday morning...
    You have to make a change to feel a difference Brad. Just be sure to document your change. Run it for a bit, then try something else, see what feels better...
    I'd like to slow compression without slowing rebound. Real hard to do when one avoids working on one's machines like the plucking Plague.
  13. Chattanooga_Mark
    Dec 25, 2009
    4,795
    2,013
    Chattanooga
    There were a few posts by KevinX regarding fork oil weight and level. From memory, I think he liked to use 10W oil at a 10mm higher level. This was to get to a bit firmer ride.
    I can’t recall ever seeing what Polaris may have used for the an ‘average’ rider. Since the only correct way to adjust CCT forks is with them fully disassembled, getting the base line is indeed important.
    Though I’d suggest using yourself as the baseline and change oil weight and/or level according to your preferences. Without rebound and compression adjustments, the only option short of internal mechanical parts is fork oil weight and volume anyway.
  14. skipbarberman
    skipbarberman Active Member
    Jan 7, 2021
    158
    166
    Hammer
    Answer :
    Option 1 - Smaller air gap as Mark mentioned above
    Option 2 - Stiffer springs in the top of the cartridge
    Option 3 - Fully Adjustable forks
    The problem with changing fork oil, is you should start with a baseline with NEW fork oil, in the brand/viscosity you want first, with all the original oil height/air gap, then adjust from there.
  15. Bikesofbrads
    May 16, 2020
    1,980
    1,123
    I’m gonna make a graph / chart measuring my current fork dive using the old zip tie method @ different speeds, note feel on certain bumpy curvy roads so I will hopefully remember how the change compares. Is a lot of variables for sure, esp since do lots of 2 up loaded riding ( either clothes n travel $hiit or groceries ) so can get tricky finding a happy medium. Thus far it’s always been about how it feels when packed full & that’s night & day away from solo commuting to work. It’ll be a fun lifelong experiment, as different tires will change things too
