Sorry - But those pictures were actually posted by another user - and I didn't think to take any. The antenna fits under the dash panel that is right behind the windshield. You remove the windshield from the motor, the fuse box access panels, 4 screws holding the upper dash panel in place and pry up the panel. There is enough room to mount the antenna between the 'under-dash' body work and the dash panel. The antenna is completly hidden - just in a different location then the original......
So i guess the 'after' pictures are 'it looks the same as before you started' ;-)
