AMSOIL MOTORCYCLE OIL | Page 10 | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Cross Country' started by crown1king, Mar 18, 2016.
  1. SPEEDFREAK
    SPEEDFREAK Well-Known Member
    Jun 29, 2015
    1,509
    626
    West MI
    cross country tour 2014
    :bigpop: this site is better than the movies but not the movie popcorn ...hey can I use popcorn oil instead of Victory oil ...oil is oil right might have to change it every 3000 tho,,would my engine make more noise?
  2. Roadkill
    Roadkill Roadkill
    Oct 19, 2015
    21
    17
    Walker Valley, NY
    Victory Can-Am Honda
    +You may hear popping...
    • Funny Funny x 2
  3. robsvision
    robsvision Well-Known Member
    Oct 21, 2013
    3,835
    864
    Bedford,NS
    Cross Country Tour
    I didn't read all the posts so I do t know if this has been answered...
    I have worked on many bike motors. And many transmisions at work.
    I have run across a handful of bearings over the years that the balls will slide in the race instead of turning. Research has suggested that 100% synthetic oil is so slippery that it's easier for the balls or rollers in the bearing to slide instead of rolling.
    Now when it comes to bike oil designed for a wet clutch. How can that oil be so slippery to make a ball slide in the bearing but still allow the clutch any amount of friction???? It can't. Not possible... Synthetic oil designed for wet clutch isn't super slippery like synthetic oil designed for non wet clutch applications. That's why it's not rated as having friction modifiers.
    Synthetic oil that meets wet clutch applications can withstand higher heat and more heat cycles. Will hold its API rating longer ect. And in some cases might be a little more slippery than normal non synthetic oil.
    Now on the reverse side. I used Ams oil in my OEM motor and had a bearing in the transmision fail at 40,000 miles.
    Just a unfortunate turn of events......or because of bearing slide?
    Personally I want the best oil for my $ .... I do believe Vic oil is overpriced..
  4. El_Spanky
    El_Spanky Active Member
    Mar 18, 2014
    628
    150
    South East Texas
    '17 Indian Roadmaster
    Have a friend that owns a bike shop Mainly HD etc.. He has mention several times ROYAL PURPLE is bad or too good they have had bearing failure on bikes that the owners used RP since new.. Just an FYI
  5. robsvision
    Oct 21, 2013
    3,835
    864
    Bedford,NS
    Cross Country Tour
    Interesting
    I suppose there could be something in the additive pkg that may cause an issue.
    I found this thread to be very interesting.
    What I have found over the years of pulling gears and replacing bearings is the most common cause of bearing skate is dirt in the oil. Smal particals of dirt ,carbon deposits, and metal flake get cought between the balls and race. The ball can't turn so they slide in the race. When this happens the bearing wears very quickly.
  6. Phideaux
    Phideaux Well-Known Member
    Feb 18, 2012
    2,306
    803
    Crossett
    2011 XC, 2005 VTX 1800 Spec 2
    I just ordered a set of E4s; they'll be here by the 3rd week of April. No kidding; they are for real.
    • Informative Informative x 2
  7. El_Spanky
    Mar 18, 2014
    628
    150
    South East Texas
    Last week a Dunlop Factory rep stop by the local Yamaha shop I happen to be there. He asked me all sorts of questions about my Victory Vision.. I might also next month.. Let us know if ya like em!!
  8. Snowman808
    Snowman808 Active Member
    Jan 19, 2016
    120
    44
    Henderson NV
    2015 Victory Cross County
    For AmsOil users.....If it can be proven that the bearing failures being experienced is due to lubrication failure, AmsOil states in their limited liability warranty that should a failure occur due to lubrication failure, AmsOil will pay for any/all repairs. Great warranty IF it can be proven that the "slipperyness" of their oil is the reason for the bearings failing.
  9. Phideaux
    Feb 18, 2012
    2,306
    803
    Crossett
    What is important about oils used in wet clutch applications is a property referred to as "stiction", or the measure of an oil to allow static friction to be maintained vs. dynamic friction to be lessened. An oil being synthetic has nothing to do with the properties that it has; it simply means that the hydrocarbon chain lengths are homogenous throughout the batch. The important property of viscosity is greatly influenced by chain length, and the additive package determines most of the other pertinent properties such as rust and oxidation prevention, anti-foaming, water dispersement and, yes, "stiction". Heat transfer capability is more complex and relies on both viscosity and additives.
    JASO is a testing protocol that is established and licensed to certain testing companies. It establishes, empirically, an oil's "stiction" property that allows a locked-up clutch to transmit torque without slippage. In order for an oil to be "certified" as JASO compliant, it MUST be tested by one of the LISCENSED laboratories; that expensive and why many oils that meet the JASO protocol aren't tested through these labs.
    Input from a degreed tribologist is really needed here.
  10. slickvic
    slickvic Well-Known Member
    Dec 22, 2011
    11,969
    5,147
    South Florida
    2011 Cross Country
    Thus no labeling on the bottle. Doesn't mean it's not Jaso compliant. Just means there's no proof ?
  11. vindex1963
    vindex1963 Administrator Staff Member
    Dec 1, 2011
    2,904
    1,211
    Payson Arizona
    2015 Cross Country...2006 Triumph Rocket 3
    Means they didn't want the expense for it.
  12. slickvic
    Dec 22, 2011
    11,969
    5,147
    South Florida
    2011 Cross Country
    Yep. I thought so. Most people just look at the pictures. If there's a motorcycle on it then it should be good. JASO ...... Shmaso.
  13. vindex1963
    Dec 1, 2011
    2,904
    1,211
    Payson Arizona
    I just looked at an extra bottle of Vic oil I have in the garage, there isn't a picture of a motorcycle on it so now what? SH** man why oh why do you confuse me so.....:D
    • Funny Funny x 2
  14. slickvic
    Dec 22, 2011
    11,969
    5,147
    South Florida
    2011 Cross Country
    Photography and drawings cost more money Vin. It's OK though. Your good cause it says Victory oil on the bottle. Go ahead and use it. Just stay away from the bottles with the little Yellow Sea shell on them. That's for your truck or your tractor. Lol
  15. vindex1963
    Dec 1, 2011
    2,904
    1,211
    Payson Arizona
    Hahaha you're killing me brother.
amsoil friction zone on motorcycle
amsoil victory motorcycles
any bad experiences with amsoil oil
bad experiences with amsoil motorcycle oil
lloydz motorworks rebuildilding clutches useing amsoil
lloydz motorworks victory oil
victory amsoil
victory motorcycle oil vs amsoil
