1 - 4 of 4 Posts
Hey y’all!
Can anyone shed some light on how to wire the rear trunk speakers to a 4 channel amp being installed in the front/inside fairing?
Thanks!!
JDR
Forget the trunk...that's for parking lots and stop lights.....here's how to do it and can hear at cruising speeds...:dance:
V-Twin Audio makes a wiring harness that connects to the low level output plug under the left side cover. That will power the aftermarket 4 channel amp. The amp needs to be able to accept 2 channel input and split it to 4 channel output. They also have a wiring harness that runs from the fairing (amp) to the back of the bike for rear speakers, either in the saddlebags or in the trunk. They have quick disconnects to make removal and replacement easy. You could easily make your own as well. Just use weatherproof sealed connectors where you want to disconnect / reconnect at.
Reactions: jdr_socal
1 - 4 of 4 Posts
