Adding USB Port | Victory Motorcycles: Motorcycle Forums
Adding USB Port
Discussion in 'Victory Cross Roads' started by Crazyhouse100, Jun 2, 2021.
  1. Crazyhouse100
    Crazyhouse100 New Member
    Apr 24, 2021
    2
    Triumph
    Hi there. New to this forum. I picked up a 2013 Cross Roads Classic with 3,900 miles about a month ago. ( Previous ride was a 2001 Triumph Thunderbird)
    Has anyone added a USB port? Looks like there is a switch blank right next to the riding light switch that could be a good location.
  2. jmstang302
    jmstang302 Well-Known Member
    Aug 18, 2013
    5,212
    2,176
    Littlestown
    On my Vegas, I use the battery tender USB adapter and run the cable for my phone up to the phone mount.
  3. Chattanooga_Mark
    Dec 25, 2009
    5,004
    2,133
    Chattanooga
    2012 CCT, Wonderful in white
    Many USB chargers draw power whether there’s anything connected to the USB charger or not. A USB receptacle is fine being wired directly to the battery. But don’t leave a USB charger plugged into it all the time. Consider connecting the USB receptacle to a switched power source to reduce the chances of draining your bike’s battery.
    I left a USB charger plugged into the 12 volt outlet in the trunk of my CCT once with the result being a dead battery after a few days.
  4. Bikesofbrads
    May 16, 2020
    2,234
    1,293
    South central/eastern ohio
    2015 victory xct & 06 katana
    Me too, but in the cubby. Is fantastic having 3 ports & using doubles can charge 6 things at once but will kill the battery quick if left plugged in for day or two.
  5. JudgeRedd
    JudgeRedd Well-Known Member
    Oct 12, 2013
    996
    338
    Hanover, Virginia
    2014 Victory Judge
    A USB wired direct to the battery is NOT ok without a switch. It will draw power with nothing plugged into it. Needs a switch if you wire it direct. Here's mine. The cover is the switch.
    https://www.amazon.com/Brand-New-Cl...913&sr=8-68&keywords=motorcycle charging port
    Other tips-
    Charging is more about the amps, less about the volts. Android phones seem to require a lot more power to charge reasonably. I say this based on previous experience with newer software versions and/ or phones tossing up a message about " I do not like this power source- slow charging" Slow charging is like not charging at all.
    Not sure about Iphones, but my wife's never threw any errors when plugged into the same socket.
    Get a 3 or 4 amp minimum.
    Careful- some brands have 2 sockets with 2 different amp ratings. like a 4 and a 2.1. I had a older unit prior to this one. The 2.1 just became useless one day. My S6 at the time just decided one day that it did not like it anymore. Replaced the unit with this stronger 4 amp- no sweat. Now I'm using an S9+ with no issues as well. Like I said- I phones might not care...
    Obviously you could tap into a wire that is only hot with key in the run position in or around the headlight bucket. I hear that is easier with the bullet style headlights. Supposedly there's a lot more room in there. The round headlights are packed fucking stupid.. So I elected to remove my tank and run it to the battery- since I had a nice built in switch and plenty of length to work with.
  6. Crazyhouse100
    Apr 24, 2021
    2
    Triumph
    Thanks for your input. Any switched unused wires lurking in the headlight?
  7. JudgeRedd
    Oct 12, 2013
    996
    338
    Hanover, Virginia
    2014 Victory Judge
    Unused? Not sure about that. Regardless- Stick them with a test light to make sure it does what you think it does. I would THINK any of them that is thick enough to secure a tap into without permanent damage would be fine.
    I would avoid smaller wires. I can tell you that when they wired my bike up- they left NO slack at all. So don't assume that you can just cut away and repair a damaged wire easily..
    If the headlight bucket turns out to be packed solid- just take the time to remove the tank and direct wire it (or tap into something under the tank or seat). Adding more to a rat's nest like that just increases the chance of something shorting out later- and probably without warning.
    If there's some electrical genius out there that knows I'm missing something here- have at it..
  8. jmstang302
    Aug 18, 2013
    5,212
    2,176
    Littlestown
    Yes there are wires in the bucket for heated grips. There may also be a switched wire under the left side of the tank, I think it should be tired to the main harness above the front valve cover.
  9. Wild Bill
    Wild Bill Active Member
    Dec 17, 2019
    177
    83
    Cross Roads
    I got a quick charge wireless around Christmas time- it has a USB port too- and an "on/off" switch. It's wired to the battery, pretty simple and sturdy- did 200 miles of teeth shattering twistys a few weeks ago- no problem!
    I think it was $30 or so- Leepiya is the brand but there's others that'll work.
  10. s-glide76
    s-glide76 Member
    Apr 21, 2015
    94
    55
    Phoenix, Az
    15 Victory CCT, 15 Triumph Scrambler, 97 Electra Glide, 76 Superglide, 06 Kaw KLR 650..
  11. jmstang302
    Aug 18, 2013
    5,212
    2,176
    Littlestown
    I have the Battery tender USB on my Vegas as I mentioned. I have not had an issue leaving it plugged in.
    I have had issue with the ones that plug into an aux plug. Crazy that the little bulb in them drain the battery down.
  12. JeffD
    JeffD Active Member
    Jun 15, 2015
    292
    156
    NE Ohio
    2014 Crossroads 8 Ball
    Wasn't the bulb, it was the transformer. It eats your battery even without anything plugged into it.
