Adding LEDs two front and rear I’m running into problems | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Vegas' started by Johann, Apr 15, 2021.
  1. Johann
    Johann New Member
    Aug 28, 2019
    21
    4
    2016 Victory Vegas
    I recently purchased LED fork cover replacement spikes and fender illuminator blinker kit with LEDs. I got a load equalizer for the rear and don’t know if I need one on every light? I have wired everything according to instructions but nothing is working correctly and my front left turn signal does not work at all. It’s not the fast blink..I’m getting a really weird buzzing noise from a block and the blinker stays on.
  2. jmstang302
    jmstang302 Well-Known Member
    Aug 18, 2013
    4,816
    1,966
    Littlestown
    Check the polarity , known to be backwards on the Lt front blinker.
  3. Johann
    Johann New Member
    Aug 28, 2019
    21
    4
    2016 Victory Vegas
    Thank you, I had no idea
  4. Johann
    Johann New Member
    Aug 28, 2019
    21
    4
    2016 Victory Vegas
    That did the trick for the blinker, now they all work. Issue still remains that none of them are blinking at all.
  5. jmstang302
    Aug 18, 2013
    4,816
    1,966
    Littlestown
    Is the bike running?
  6. Johann
    Johann New Member
    Aug 28, 2019
    21
    4
    2016 Victory Vegas
    Yes sir...runs like a top.
  7. PDXLaserGazer
    Jun 3, 2013
    4,131
    1,430
    Molalla, OR
    When you test the lights, is the bike running or off with key and kill switch on? Pretty sure that was the direction. Do they work with bike on/engine off? Bike running? You need 1 for each side, the front/rear are spliced together in the harness. If the resistance is too high they'll turn on and stay on.
  8. Johann
    Johann New Member
    Aug 28, 2019
    21
    4
    2016 Victory Vegas
    So far I have not started to bike to see if there is a difference between running and not running. I Key up the engine and the headlight and brake light come on, I am gauge turn signal right in the turn signal will come on and stay on. I have to use self canceling to turn it off. Same when I use the left turn signal. however, when I engage four-way hazards they all work and fast blink.
  9. PDXLaserGazer
    Jun 3, 2013
    4,131
    1,430
    Molalla, OR
    4ways use flasher module, turn signals use flasher + auto-cancel module. Not sure how that affects it but seems to. If you remove the load equalizers, do they fast flash? If the LE has 3 wires, I believe 1 goes to ground and the other 2 go to left power and right power. 1 LE in that case should do the trick for the whole bike.
  10. Johann
    Johann New Member
    Aug 28, 2019
    21
    4
    2016 Victory Vegas
    . There’s a picture of the load equalizer that I’m using. With the load equalizer is plugged in the rear turn signal’s are lit up like running lights, when I engage a blinker they brighten but still don’t blink. When I remove or unplug the load equalizer but the rear blinker lights do not stay lit as running lights that is about the only difference.
  11. Johann
    Johann New Member
    Aug 28, 2019
    21
    4
    2016 Victory Vegas
    There is a thumbnail or picture of a single block and there is a buzzing noise coming from it
  12. PDXLaserGazer
    Jun 3, 2013
    4,131
    1,430
    Molalla, OR
    Is it a load equalizer or a run/turn/brake module?
  13. PDXLaserGazer
    Jun 3, 2013
    4,131
    1,430
    Molalla, OR
    LE should have 3 wires, 1 common and 2 for the left/right signals. A run/turn/brake would be connected also to keyed power and the tail/brake lines.
  14. Johann
    Johann New Member
    Aug 28, 2019
    21
    4
    2016 Victory Vegas
  15. Johann
    Johann New Member
    Aug 28, 2019
    21
    4
    2016 Victory Vegas
    It is a run break turn module. I really appreciate all of your input and help. I am brand new with this.
