I have a 2013 XCT and want to add the CustomLED Magic Strobe Brake Light Flasher so that all brake lights (top case/rear fender and Kuryakyn LED Sabertooth LED Saddlebag accent lights) all flash when I apply the brakes
The PO had an isolated trailer wiring harness installed under the rear fender, so I was thinking on installing the brake flasher there where they taped into the rear brake light/turnsignal/running light wires and run an additional wire from the output side of the flasher to the brake light wire in the 'pigtail' wiring harness for the top case's wiring system.
This should work, no?
Anyone have any issues with the CANbus system/Cruise Control when they tried hooking up this brake flasher to all these LED brake lights??
Dusty
Dusty
