1 - 7 of 7 Posts
Happy Holidays to everyone 🎄
I have a Magnum X1 2015.
Basically, my project is simple (that's what I thought at first), I want to get the Tour Pack speakers to work as well as the ones in the saddle bag.
I got a "Y" connector from vtwinaudio.com. I was thinking that would be just a plugplay job but I was wrong...
So after looking around on the web, as some of you should already know, it is necessary to add an amp for the tour pack speakers. So...I decided to add an amplifier for the speakers in the tour pack. Isn't that simple? Ohhh Nooo it is not!!
Long story short, I installed the new amp just next to the original one under the rear fender.
What I think now is splitting the wires coming from the output of the radio to the amp to feed the input of the new amp. And then making the connections of the output to the "Y". So, when the tour pack will be in place, I'll just have to connect it to the "Y" and every speakers will work all together.
looks clear in my head...hoping it's clear for you while reading this 😅
Now my question is: on the connector plugged into the OE amplifier, there should be the wires coming from the radio to feed the amp with the non-amplified signal. What is the color of the "unamplified" wires ?
I post some pictures to help.
Thanks for your help and Happy New Year 2023 to all of you.
Bicycle handlebar Automotive tire Handheld power drill Bicycle part Wood
Gas Electrical wiring Cable Machine Wire
Automotive tire Hood Motor vehicle Automotive design Automotive exterior
Black Motor vehicle Gas Auto part Electrical wiring
Finger Electrical wiring Cable Personal protective equipment Wrist
@slickvic or @yankphan can you help?
@Deeper do you have a manual?
@md2420 I have the owner manual by Victory but no helping information in it about the sound system.
I also contacted RadioSound (Ntouch amplifier manufacturer). A guy named Eric Weber from RadioSound told me he can't help me because the "extreme secret" of the wiring diagram. (See photo)
Font Technology Multimedia Screenshot Gadget
I also contacted RadioSound (Ntouch amplifier manufacturer). A guy named Eric Weber from RadioSound told me he can't help me because the "extreme secret" of the wiring diagram. (See photo) View attachment 638854
Didn’t mean the owners manual, asking if you had the service manual (which should contain wiring diagrams)
Fellow Vog member BBob has graciously gathered them for us. Here’s the link. MediaFire
  • Informative
Reactions: Bikesofbrads
Saved from a post.
Rectangle Font Parallel Pattern Number
told about a Magnum from Vtwin audio. Their harness is made for XC and if you try to run bags and trunk speakers the conclusion was a separate source harness to the trunk. Underpowered split sources. If you had an aftermarket radio you could tap into the dead low level wires going back to the plug for the trunk. Best Magnum radio is the Skywalker Mvh512bs plug and play Pioneer on facebook.
How about a 4 channel amp to power both rear sets? You'd only need one source input (which could be a high level source), then run new speaker lines (which I'd do anyways) seems a better solution. Maybe something like this? SounDigital EVOX2 400.4 - 4Ω $250.00
How about just 1 four channel amp for all the rears, like what btj said ^^^
1 - 7 of 7 Posts
