21 - 28 of 28 Posts
That's the ONLY thing that has been replaced on my 2012 with 32K miles. The ABS sensor. Started coming on and then going off. Increasing on time over the span of a few weeks and then on full time. Slow failure. Got it replaced...no more issues.
Check part numbers but I think they are the same. Honda of east Toledo has good prices but if I give my local dealer Randy's a price from them he will meet it. Fortunately I have good dealer. Glad I don't need him other than accessories but nice to know we have good one.
Salut,
Hi,
Testes le capteur avec ce montage ;)
You test the sensor with this arrangement ;)
il faut ensuite tourner la roue doucement pour voir la Led clignoter. Si la Led clignote, le capteur est Ok
it must then turn the wheel slowly to see the LED flash. If the LED flashes , the sensor is OK
Cordialement,
Denis
Edit : Mon problème avec l'ABS
Capteur ABS Avant :
ABS sensor Front:
Passage du fil :
Passage of the wire :
Le fil touche le disque :
The wire touches the disk :
Résultat évident :
Obvious result :
Le fil faisait contact avec le disque de frein.
The wire made contact with the brake disc.
Denis
21 - 28 of 28 Posts
