Last Thursday I wanted to replace the spark plugs on my '10 XC. It is a spring thing, I just like to do this once every year. As I pulled the forward wire off, by the way, I use pliers to get way in there, the metal end that connects the plug to the wire stayed on the plug. I'm like WTF... I pulled the clip off the plug and looked in the wire. After seeing which way the clip was fastened, I stuck the clip into the wire as far as I could get it to go. I changed both plugs and attached the wires, then fired up the motor. Runs just fine...no issues what so ever, except that voice in the back of my head...nagging me to change both wires now as I have a nice road trip coming.
Ordered a set of wires from Witchdoctor's, in 2 days time, have the wires in hand. Great guys and gals there. Monday morning, get the bike on the centerstand, pull my custom cheese wedge off to expose the coil and wires. Proceed to pull one wire off the front plug(the clip stayed with the plug again) and the coil. Stick the new wire on the plug, then the coil. I cant seem to stick the coil end on...it won't go in all the way. Again WTF... The second side(rear cylinder) goes easily. I look at the old wire...the female end seems to be broken inside the coil. GREAT!. I try to patiently remove this clip using pliers. No Joy! Now I remove the 4 bolts holding the coil in place, so I can better see what is going on. Now, that voice in the back of my head is nagging at me, that I will soon have to replace this coil. I say F*^% no. that's not gonna happen. Well... after trying to pull this broken clip off the coil, I end up pulling the male end off the dam thing. Now that the piece is in my hand, they separate with a whisper. FUNNY!
Ordered the coil from a Polaris dealer...this unit is used on a variety of Bikes, wheelers,& UTV's. I swear...all I wanted to do is change the dang plugs. I'm gonna need therapy over this deal...I know it!
