99 V92 fuel pump issue, good pump but wont run. | Victory Motorcycles: Motorcycle Forums
Discussion in 'Tech Q&A' started by Luke M, Jun 10, 2015.
  1. Luke M
    Luke M New Member
    Jun 1, 2015
    9
    1999 Victory V92C
    I have a V92c that has something going on with the fuel delivery system. I got a new pump and installed, it would not work either. I hardwired the old pump in and it pumps great, wire it up like it is supposed to be and nothing. I have checked the fuses and relays, nothing wrong with them. I have checked the wiring plug to the ECM and it looks great. The pump would stop working here and there on the road a few times but would normally fire up again after setting for a moment. I have been trying to figure out this problem for 2 weeks now and am starting to go bald with this issue. It was recommended to me to check the "fuel shut off safety switch", I have not heard of this on a Victory of this age. Any help would be greatly appreciated, I dont have much money at this time cause the truck is doing its job of needing repairs also and I need the truck more than the bike.
    Thank you in advance!
    Luke M.
  2. kevinx
    kevinx Well-Known Member
    Sep 1, 2009
    3,229
    849
    1955 Hyda Glide
    Does the pump cycle with first key on?
  3. Luke M
    Luke M New Member
    Jun 1, 2015
    9
    1999 Victory V92C
    No not at all, everything else works like it should though. The light comes on the cluster activates and lights up like it used to just no pump.
  4. kevinx
    Sep 1, 2009
    3,229
    849
    1955 Hyda Glide
    Check connections on starter relay
  5. Luke M
    Luke M New Member
    Jun 1, 2015
    9
    1999 Victory V92C
    Starter turns over fine, everything works as it should but the pump will not run. I have checked the connections at the main electrical (battery, fuel pump, starter, shut off switch, relays, fuses, ECM wiring, harness to relays and fuses, wire connectors).
  6. kevinx
    Sep 1, 2009
    3,229
    849
    1955 Hyda Glide
    I understood what you were saying. More goes to the starter relay then just the starter. Also check the ground on the rear bolt of the left passenger floor board mount
  7. Luke M
    Luke M New Member
    Jun 1, 2015
    9
    1999 Victory V92C
    I looked more into that this morning after you had mentioned it, I removed the bolt and checked for corrosion and it all looked good. Still no fuel pump engagement. just out of curiosity shouldn't the motorcycle start with the fuel pump hardwired and engaged?
  8. Luke M
    Luke M New Member
    Jun 1, 2015
    9
    1999 Victory V92C
    Is there some sort of crash safety switch on this bike?
  9. dann
    dann Active Member
    Jul 6, 2012
    253
    31
    Cedar Lake
    1999 V92C
    Do you have a repair manual? If not pm me your email address and i will send you the fuel system test procedures and repairs.
  10. catwrench59
    catwrench59 Well-Known Member
    Dec 14, 2013
    1,778
    459
    Lacon
    2012 Victory Cross country tour
    Give KeninX a call at Southern motorworx his been good enough to try to answer on here. sometimes it's hard to get things across in emails and threads a phone call will make it much clearer
  11. Luke M
    Luke M New Member
    Jun 1, 2015
    9
    1999 Victory V92C
    Ok I am sorry it has been so long for a reply here, I have spent alot of time looking at this bike and have come to the conclusion that its the ECM. Before I go out and spend the $880 that I dont have, does anyone know of a way to test the ECM to make sure this is the problem? I would greatly appreciate the help here! Thank you in advance!
  12. dann
    dann Active Member
    Jul 6, 2012
    253
    31
    Cedar Lake
    1999 V92C
    You can call a dealer and see if they can test it. Check on ebay for a ECM I don't think I would spend that kind of cash if I wasn't sure it will fix the problem. If you can pick one up on eBay for a couple hundred that might be worth the gamble. These old cruisers can be a ***** to repair because of lack of support.
    Good Luck
  13. Luke M
    Luke M New Member
    Jun 1, 2015
    9
    1999 Victory V92C
    The dealer told me that they could not test it with out the bike and is a min $260 just to bring the bike through the door then $109 per hour to "start from the beginning" as they "need to see for them selves" what is going on. The guy told me I would be looking anywhere from $500-$1000 just to diagnose with out parts. I did find one on e-bay and think I might buy it to try it out. This is starting to SUCK!
  14. catwrench59
    Dec 14, 2013
    1,778
    459
    Lacon
    Have you contacted Rylan Voss @ the Vicshop or any of the other long time Victory experts yet? Before spending any more money guessing I would seek advice from one of the well know experts. Rylan does alot with the older bikes and can be very helpfull. I see a lot of ECMs get the blame and be replaced when the problem is some place else. Best of luck with this. I wouldn't be going to the local dealer that gave you that quote. He probably isn't familliar with the older bikes any way and they are different
  15. tree1979
    tree1979 Well-Known Member
    Jan 10, 2014
    4,221
    1,391
    Birmingham, AL
    2007 Victory Kingpin
    Agree with Cat. CALL Rylan at theVicShop (Contact or KevinX (352) 215-3253 before you go any further. They will treat you better than your dealer.
1999 victory v92 fuel pump and fuel filter
1999 victory v92 fuel pump not getting power
1999 victory v92c not starting up
2000 victory v92c fuel pump diagram
2001 victory v92sc no power to fuel pump
2002 victory v92c fuel pump
2002 victory v92c no start but it turns
2002 victory v92c where is the fuel shutoff switch
2005 victory vegas fuel pump not coming on when switch turned on
99 v92 fuel pump location
replacing victory v92 fuel pump
vctory fuel pump v92c
