87,88,,91 octane? | Page 6 | Victory Motorcycles: Motorcycle Forums
87,88,,91 octane?
Discussion in 'Tech Q&A' started by sean rrt, Mar 15, 2015.
  1. Pauljp
    Pauljp Well-Known Member
    Nov 28, 2013
    1,277
    813
    Quebec Canada
    2014 Cross County Tour
    Maybe it's just me, but I have noticed when I run 87 octane that my mileage per tank really goes down.
    When I use 89 octane it goes back up to normal.
    Basic Canadian metric numbers, with 89 I get about 400 kms per tank, and with 87 I get about 300 kms.
  2. wvrider1
    wvrider1 Well-Known Member
    May 20, 2012
    4,014
    1,333
    WV Appalachia
    Goldmist/Black 14 XCT
    I run mid grade always. Octane needs are based on compression true? At 9.4 compression, do you really need 91-93 octane? Most you folks burn 87 in the family truckster with the same compression. JMHO, YOMV. :beer3:
  3. Tenax66
    Tenax66 Active Member
    Aug 12, 2017
    960
    202
    Victory magnum 2016
    I dont think its just you..thats a substantial difference. In mixed driving on both 89 & 91 with 2 tanks gone in my new magnum, 440km to empty
  4. rodhotter
    rodhotter Well-Known Member
    Aug 5, 2013
    1,979
    258
    pennsylvania USA
    2013 victory hammer
    my 13 hammer gets top tier premium 93 oct always, with corn unfortunately, but a new station just opened this week locally advertising no ethanol + they pump all the fuel, gotta check the octane though!!!
  5. Flyboy
    Flyboy Well-Known Member
    Aug 29, 2014
    16,009
    6,169
    Victory Boardwalk
    I find that Gate in my part of the Country uses 89 octane crapanol free, but others list theirs as 87. So as @rodhotter says, pay attention. Mine seems to run better on 93 octane, but it has non-efficient corn squeezings in it... So if the Scooter is going to sit or a couple weeks, I use the 89 Marine fuel.
  6. huberei
    huberei Active Member
    Feb 10, 2017
    192
    29
    gunner
    Well, in switzerland you only get 95 or premium is 98 octane... for the same engines like you have...
  7. rodhotter
    Aug 5, 2013
    1,979
    258
    pennsylvania USA
    2013 victory hammer
    when the local shell now sunoco went from no corn to 10% eath i lost about 5 mpg on average with my traded 1200 porkster!! our government subsidizes corn + we pay for it + get stuck with less mpg + other issues using it!!
    • Winner Winner x 1
  8. WHITE_VIC
    WHITE_VIC Well-Known Member
    Jan 23, 2016
    1,279
    230
    Victory cross country
    I doubt you lost 5 mpg when they switched
  9. rodhotter
    Aug 5, 2013
    1,979
    258
    pennsylvania USA
    2013 victory hammer
    i know it seems like a lot, but i was hitting 60 before, solo + casual on an 06 1200 porkster, later i only seen mid 50's. not a critical computation because motorcycle mpg's matter little to me!!!
  10. scottie409
    scottie409 New Member
    Oct 6, 2013
    12
    niagara region ontario canada
    13 Vision
  11. rodhotter
    Aug 5, 2013
    1,979
    258
    pennsylvania USA
    2013 victory hammer
    heat affects octane requirements as it does oil as well!! ester oils which are group V true synthetics resist breakdown better than any other type of lubricant + they are said to reduce engine temperatures as well!!
  12. scottie409
    Oct 6, 2013
    12
    13 Vision
    I have a 13 Vision with cams, wheel and power commander. I put 8000 kms in about 7 weeks and was running regular gas.
    I found that I had difficulty using 6 th gear except on flats with no load on engine otherwise it would ping and sound like ****.
    I switched to 91 high test and it made a huge difference in drivability. Now using overdrive is a pleasant experience. I will try to run mid grade to see if it will still be ok. I can't believe how much better it drives on High test.
    Your truckster is water cooled therefore manages heat better
  13. rodhotter
    Aug 5, 2013
    1,979
    258
    pennsylvania USA
    2013 victory hammer
    water cooling is helpful but many systems are undersized. most manufacturers tune more aggressively + use higher compression ratios as well, so using higher octane especially in heat + of course if you drive slow locally which negates most of the water cooling unless you have a BIG fan cooling your heat soaked cooling system, + of course high heat kills oils much quicker unless its Ester based oil!!
  14. rman
    rman Active Member
    Mar 19, 2011
    122
    31
    meriden
    04 victory kingpin
  15. rman
    rman Active Member
    Mar 19, 2011
    122
    31
    meriden
    04 victory kingpin
    Ethanol is used as an octane booster. That is what keeps the fuel from igniting too early. Instead of burning it allows the fuel to compress then explode in essence producing more power over (91 over 89) even though lower octane has more energy. It is just more
    efficient in higher compression motors that require it. It is said that the use of 91 in a lower compression motor will produce carbon build up. The detergents in the fuel today should reduce that build up. As everyone says here, if you don't have pinging or other motor noise use the lower octane as using higher octane does nothing for your motor, just bleeds your wallet.
does race fuel stop pinging on victory motorcycle
octane promotes carbon
running a motorcycle on 91 octane made for 87octane
tunning a motorcycle to take 91 octane
victory 106 pinging sounds like
