It might seem early to some for a complete tear down, but it was 20 degrees outside for about 2 weeks I needed something exciting to do. When out in cold weather I would get some squeaking from the rear end when sitting on the bike, plus I needed to replace the rear tire. Upon inspection the bearings, bushings and seals were all in good shape. Victory actually used grease on these parts. (My Vmax left the factory with dry head bearings!) There are 4 ball and socket joints, 1 at the lowering link, 1 at the shock, and 2 on the swing arm. The shock joint is sealed so it was good. The other 3 joints were all dry and dirty. The swing arm axle was in the early stages of corrosion on the right side. I cleaned up the axle and applied water proof grease, thoroughly cleaned the ball and socket joints and packed them with water proof grease. These joints really swivel around nicely now. (I think i found the squeak issue) added more Moly grease to the needle bearings in the shock saddle and swing arm for good measure and reassembled.
Going back together I installed the rear tire per HC recommendation, never touching the axle adjusters. I rigged a ratchet strap around the tire and pulled it tight against the adjusters and tighten the axle nut. Perfect!! Belt is still the correct tension and it rides centered. Maybe just a tad left, it always seems to go left just a little. That was easy!
Rear suspension is now smooth and quiet.
