I hope he has his CDL.That's gonna be a WIDE left turn!
Turn? Not sure you could keep traction enough to turn. I see this and think of those videos of supercharged drag cars that chirp the tires at idle while putting around the parking lot.That's gonna be a WIDE left turn!
I thought the same. The torque that this engine is going to put out is going to be massive. And then there is the prospect of forced induction... :22yikes:Turn? Not sure you could keep traction enough to turn. I see this and think of those videos of supercharged drag cars that chirp the tires at idle while putting around the parking lot.
That is alright, the torque alone will keep ya planted.... I bet the tranny will be clunky, if one can tell.That's gonna be a WIDE left turn!
No, no, it will be some kind of Purple Spectre - Rotellin advanced Quicksilver that is JASO-EPA approved 30W60 semi-mineral mix of carbon-ceramic, ah stuff.OK....you knew it was coming....what kind of _____...does he use....you fill in the blank![]()
It just doesn't have any excitement. How much different can batteries be ? I mean there's what .... 3 different types ? Lead Acid, AGM , Lithium.
Although I currently use the AGM, which is a glorified No Maint Lead Acid (limited life), I would prefer old school Lead Acid that I had to maintain. I usually get about 7-9 years and only 4 for the former.It just doesn't have any excitement. How much different can batteries be ? I mean there's what .... 3 different types ? Lead Acid, AGM , Lithium.
I like the batteries at the battery bulb store.
$110 Duracell and extra mounting area on posts for accessories.
Oh boy. Now look at what we've done.
Had same issue 6 months ago and all that and still ended up changing the battery.Rode today. Bike acted funny starting up then stalled. This happened 1/2 way thru the day. Hmmm.
Made it thru the day. Got home and checked battery. Both terminals loose and dirty. You know the drill. Perfect now. Fires right up.
