I had installed a new exhaust and was waiting for the PCV to come in. Thought I would take the bike out for a little ride.Noticed I lost my speedo and odometer on the way back from work, also when I got on the throttle the engine started to run really ruff at 4,000 rpm. I installed the PCV and nothing changed. Had a buddy check that all the connections where good and everything appeared to be good. I found a post about the same issue and the O2 sensor seemed to be the issue so i disconnected them and check them. Everything once again seemed to be fine but the bike is still having the same issues. If you need more info please ask need as much help as I can get, I have tapped out any local help.
