I cannot determine the cause. Have not changed tires, have not hit any potholes or other, all seems tight. Next step is to remove front tire and inspect. Any recommendations or ideas?
Tire wear or flat spot, check pressure? Out of balance? Maybe try some ride on or balance beads, something like that if you think it's out of balance. Good luck and welcome to the forum from NM.I cannot determine the cause. Have not changed tires, have not hit any potholes or other, all seems tight. Next step is to remove front tire and inspect. Any recommendations or ideas?
Agreed... check yer triple-tree race 'n bearings.On a slight incline apply your front brakes and see if you get any movement beyond just the shocks neck bearing looseness, jack up the front of your bike And check the wheelbearings to see if there's any movement...
