2013 Cross Country Tour Cruise Control Problem | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Cross Country' started by burbansk, Sep 26, 2020.
  1. burbansk
    burbansk Active Member
    Dec 22, 2019
    123
    103
    Michigan
    2013 Victory Cross Country Tour, 2000 BMW 1150 GS, 2008 Honda TRX 700 XX
    Hello Gents, After installing my FMB Phatt apes my cruise control will not engage. The power on-off button lights up when turned on but when I hit the set button nothing happens. Everything else on the bike works correctly ( Throttle, Idle, Brakes, Brake switch, etc. ) Am I missing something. I can't find anything wrong.
  2. uk_john
    uk_john Active Member
    Jul 25, 2008
    194
    27
    London
    Cross Country 2012
    Return throttle cable needs adjusting or the switch in the cable faulty at a guess
  3. wvrider1
    wvrider1 Well-Known Member
    May 20, 2012
    3,991
    1,311
    WV Appalachia
    Goldmist/Black 14 XCT
    ^^^What he said, the return cable cause most problems when guys install a 1/4 turn. Same cable different problem is the cruise switch. It is usually at the front of the fuel tank along the frame. That was my issue. Just pull 1 wire and try it out.
  4. Pauljp
    Pauljp Well-Known Member
    Nov 28, 2013
    1,256
    786
    Quebec Canada
    2014 Cross County Tour
    I made a video on testing the cruise control. It might help you.
    • Informative Informative x 5
  5. burbansk
    Dec 22, 2019
    123
    103
    Michigan
    Thank you Paul, So since it is probably my Throttle cable cancel switch being as I did put new bars on and messed with my cable adjustments do I need to adjust the slack in the cable more or do I need to replace the switch itself. Sorry for all the questions but you seem to be the expert on these bikes.
  6. jmstang302
    jmstang302 Well-Known Member
    Aug 18, 2013
    5,510
    2,298
    Littlestown
    It could be the routi,g of the cable? Did you wire tie the cable? The cable needs to be able to move freely.
    Unplug the switch, take it for a ride, if if works...the cable needs attention.
    My XC requires 2 - 4 taps to set the first time for each ignition cycle. Then sets and resumes with 1 touch...
  7. Alwhite00
    Alwhite00 Well-Known Member
    Sep 13, 2020
    494
    342
    Victory
    Great video Pauljp. Lots of great information.
  8. Pauljp
    Nov 28, 2013
    1,256
    786
    Quebec Canada
    Your throttle cables are out of balance. The "Push" cable is constantly activating your switch thus always trying to turn off the cruise. You need to loosen both cables, let the throttle grip center itself, then adjust both cables at the same time to keep the grip centered. I put a piece of masking tape on the bar end cap and another right beside it on the grip, draw a line across them and watch that line for movement while adjusting the cables. You want the grip to stay centered.
    Of course did you test the switch first to make sure that it is the problem by disconnecting the wires?
  9. burbansk
    Dec 22, 2019
    123
    103
    Michigan
    Well here is what happened. When I went to put it in the diagnostic mode the cruise dash light would stay on all the time no matter what I did. I then noticed that the cables seemed way to tight on the frame where they were tie wrapped so I removed the tie on the frame off of the cables and now things seem to be working just fine. The diagnostic check went just fine and I am going to take it out and check the cruise . Thanks to all for the great info. Bruce.
  10. IndyVictory
    IndyVictory Well-Known Member
    May 29, 2020
    1,338
    484
    Indianapolis
    Sounds like you just had binding in your throttle cables and not moving freely.
  11. burbansk
    Dec 22, 2019
    123
    103
    Michigan
    When I tried to get into the diagnostic mode as Paul's great video explained the cruise light stayed on after releasing both buttons. No matter what I did the light stayed on. I then thought about the cables as JMStang302 suggested. The cables were factory tied by the frame and they were way to tight and binding. Cut the ties and all was well. Light went out and I was able to do a full diagnostic check as Paul said and it went just as he said. I have a feeling my cruise control will be up and running next time I take her out. Thank you all for the help. Bruce.
  12. IndyVictory
    May 29, 2020
    1,338
    484
    Indianapolis
    Glad you got it solved.
  13. luckystryke
    luckystryke Well-Known Member
    Nov 17, 2013
    87
    121
    Middle Tennessee
    2012 Cross Roads
    Awesome video. Thanks so much for the help. I really found adjusting the throttle cables quite useful. All is working again. Again, thanks for the help.
