Hi all,
That's my story today ...
Starting from a friend's house, I switch my gears normally and I see that the "Neutral" light and the indicator come on at every gear!
I find this weird and I test while staying on the same gear by simply moving the lever, the light "Neutral" lights up every time.
I stop to turn off the ignition and restart and can not start !!
The battery level is below 12v while it was 14.4v all along the road.
The starter does not really start and reminds of a speed gear engaged.
I unplugged the clutch lever contact plug, a friend came with a battery and I was able to get home.
You would have an idea of the problem?
Thank you for your feedback.
Denis.
Denis.
