So, what's the latest with all this? Curious minds want to know! RR
LOL, when pressed Frank will admit that he only uses Amsoil and Black Paint to fix Motorcycle problems.bubba said:I use Amsoil, have no issues on my 2011
I also believe in witch doctors!!!! I also believe that when the bike breaks down there is a problem. I have a 5 year warranty so I am not concern. I am all about preventive maintenance and avoiding issues on the road. In the 11 years I have owned a Vic, I broke down once on my 00C. Bad fuel pump. Maybe that's why I like loud tunes and loud pipes when I ride. RIDE them!!!keithgrey said:LOL, when pressed Frank will admit that he only uses Amsoil and Black Paint to fix Motorcycle problems.
This is exactly what I experienced this weekend. Ambient temps were around 85°F. I did not hear any grinding except when in neurtal and I let out the clutch and oil temp was over 225°. When in gear I do hear a pronounced growl/grumble from the gears and a louder whir from something when the oil temp is closer to 250° but don't hear them when the temp is cooler like around 200°. I wonder if it is the Victory brand semi-synthetic oil thinning out at higher temps. One member said he uses Amsoil and has none of these complaints. I was considering switching to that or Mobil1 20W-50 full synthetic. Anyone using that? I have also witnessed a couple of incorrect gear number displays. What I see is more of a delay in showing what gear I am in after I shift. Once it did show 6 when I was in 5th but that was right after I did some quick side to side swaying. It returned to 5 when I leveled out. I wonder if the sensor for the gear position display is electronic or mechanical. Anywho, I am taking it in soon for the 500 mile service and will voice my concerns and show them this thread. Glad to know I am not the only one. Regards, steviejBotein said:I just got my XC a couple weeks ago and it rattles when the oil is warmed up in neutral as well as 1st. I'm going to bring it up when I take it in for my 800km inspection.
Both of my Kingpins have made a grinding or rubbing vibration noise that could be felt also just before coming to a stop. Thought it was something to do with the front rotor and calipers. I now believe it comes from the rear pulley and drive belt, after centering belt on rear pulley when adjusting belt the noise seems to have stopped.jdav3 said:I have the same noise on mine when shifting down to first gear while rolling only at about 10mph. 2011 Cross Country
