Yes, the bike will ride two up. I have a matching cruiser seat for the rear that my wife would divorce me over if I did not put it on. So, I have some fabricating to do on the seat itself - I already cut the "ears" off the bottom of the seat so they can grow. I am working on some cool shaped extensions that will fit over the fender to bolt into the side. I can still take it off and ride solo without scratches to the paint.
And yes, I am working on sub-frame bracing much like Eriks bike, but my front bracket pattern is a little different. You can bolt those suckers in there several different ways. Actually, I am considering doing a complete "bolt on" set of brackets - no welds! I have an interesting idea with some larger angle iron that I think is safe, and prevents any welding from taking place. Nothing against welding, but you can tighten a bolt enough and lock it in place with Lok Tite that if it ever did get loose you know it. With welds in blind spots, it can be difficult to tell there is a problem before theres trouble.
Everything seems to be going pretty good. Tommy Jo (guy holding the tires) had an awesome idea for extending the front pulley cover with some stainless extension tubes.
We did have a heck of a time getting the wheel on and off the swing arm the correct way with all the spacers in the right places with the pulley. I used my 05 pulley and had to drill out the holes to make the lugs fit through, but it worked out great. I put stuff on backwards - typical "I have never done this before" kinds of things going on. The best one was trying to use spacers to fill the gap because we forgot that the brake caliper was suppose be a spacer on the axle.
The only real concern I have at this point is (after all the on and off with the wheel) the alignment. With the spacers and everything in place, the wheel was very tight to get in place. When the tire seems "centered" the tick marks on each side of the axle are off by almost one whole tick mark. If I line up the ticks on each side, the tire "seems" to push left of center. ???? I can't be riding crooked, but I don't know if it has anything to do with the "After market" chrome axle bolt on the left side of the bike that has its own ticks.
Any idea?
Oh yeah, what size are rear pulley lugs? We had to buy some "get by's" at the parts store. Parts guy seem to think they are 11MM with a 1.5 course thread = UNCOMMON.
And what the hell is up with Metric v. Standard bolts all over the bike? It's an American bike, but Victory must have been buying bolts that were on sale from all over the world - gets aggravating to keep digging through 2 sets of tools.
