Check battery connections and change 40amp breaker. Happened to me when my bike was new a few times. Changed the breaker and hasn't happened since (40,000 kms)
Thanks for the reply. Did u waterproof the breaker? I've been told epoxy is a good idea. Also - how important is torquing the terminals on the battery? Hard to believe I have to do this to a 2yr old bike but I won't give my dealer a blank cheque either...Check battery connections and change 40amp breaker. Happened to me when my bike was new a few times. Changed the breaker and hasn't happened since (40,000 kms)
Hi - thx for your reply. Unfortunately it didn't. It came with an extended power train but not full coverage. My dealer even suggested that perhaps I have mice in my garage that ate the wiring harness... (Uh... No...)Didn't your bike come with 5 year warranty,
Regards
Hi kevinx - thx for sharing. Totally agree with your recommendations - I picked up the part from Napa today and will replace it tomorrow. Wish I had a lift - my chiropractor will love seeing me after this. I'll definitely clean the terminals and torque down / use some dielectric grease too. Thx againChange the breaker. You can get it from NAPA for a reasonable price. Fairly common issue
Though I seriously doubt the battery cable is this problem. These bikes are hyper sensitive to battery contact. I check battery connections on every service
Buy an extra one and throw in your bag.Hi kevinx - thx for sharing. Totally agree with your recommendations - I picked up the part from Napa today and will replace it tomorrow. Wish I had a lift - my chiropractor will love seeing me after this. I'll definitely clean the terminals and torque down / use some dielectric grease too. Thx again
Well said. I've read some strings here that a few riders experiencing this issue doesn't make for a recall - but it seems a little more widespread than that. If it's widespread - I'm mean we're talking about total power loss on a highway - with the potential for deveatating consequences - you'd think someone would recognize fixing this issue is cheaper than the alternative. On the other hand - if it's not a widespread issue - you'd think that the dealer would have at least heard of it and wouldn't suggest a two hour charge for a diagnostic that won't reveal anything...Recall? Victory no speaka da Recall! And when they do - they sit on their butts til they are good and ready to think about it. Then, maybe they will get the replacement parts out or maybe they won't! Good bike - not so good Customer Service!
Sure do. The part # is 782-3116 - good in Canada and the U.S. I paid $15 tx incl Cdn - I believe it's approx $10 USD. I test rode the bike today and all seems okay...Do you have a part # and price from NAPA on the breaker??
thanks
Okay... 50km ride after a light rain this afternoon. About 10degrees and damp conditions. Bike started up on first try, iPhone plugged in / music on and grip heaters flashed up too - to draw max amperage. Happy to say - no issues. Will be taking it for a day ride tomorrow so stay tuned...Ok - want to make sure no one thinks this was my 'one and done' post.
I picked up the breaker from Napa and dismantled the lower left side of the bike. A lot of grime on initial inspection. The red plastic cover was deformed - I suspect from heat - only source I figure is from the breaker itself(?) - the boot is of poor design and certainly doesn't protect the breaker - at best only the two posts. The breaker itself was covered in grit - likely carried in my water - and a lot of grime. Both terminal connections and each battery post were scrubbed clean, dielectric grease applied and connections beyond tight.
Hope this does the trick. Started on first try; test drive today when it stops raining. More to follow...
