Can't wait to see all this.
Look forward to seeing the pictures and the Dyno tune chart, good luck, sounds like a good choice of upgrades.So here is my first post. I've been reading threads, learning this bike and just gaining knowledge.
I figured it was time to weigh in and get some feedback.
I have (had) a bone stock '12 Vegas 8 Ball. Thought it was about time to hear this big Ole 106'.
So I order the following very basic stage 1 items.
- Freedom Performance Radius exhaust (black due to being an 8 Ball).
- Lloyd's gaskets.
- Dobeck EJK Gen III.
- Arlen Ness Big Sucker intake.
- VictoryOnly's short sissybar.
(Pics coming soon)
I'm installing everything over the next 2-3 days.
Removing the the old exhaust wasn't fun. PB Blaster helps alot.
Also wanted to add using a plumber's wrench makes removal of the O2 plugs from the factory exhaust so much easier.
Installing the Arlen Ness Air intake:
Removing the OEM air box is also a treat. Witchdoctor has an awesome YouTube Vid. Only a few things I'D add; Used press and seal over the intake, rubber banded on aroind the intake manifold. Additionally, I used a Dremel with a multi-purpose cutting bit to cut up the OEM air box, super simple, just a little messy 10 minutes it was out. Arlen Ness Big Sucker mounted using a little Permatex high temp. sealant to aid in sealing from air intake leaks.
Exhaust being mounted using Lloyd's gaskets.
Location of the Dobeck EJK.
I removed the Hex tools from the factory battery plate, flattened one of the hex tool mounting tabs on the battery holding plate. I did this so I could mount the EJK under the plastic battery compartment cover, completely hidden, yet easier to get to then mounting under the seat.
I will write up directions soon, with pics.
I wanted to open this thread for any additional comments, tips, questions etc. ......Ready, 1, 2, 3 Go!!!
I don't think you Dyno a bike with a gen 3 EJK. It isn't hooked to a computer it is adjusted through the faceplate buttons.Look forward to seeing the pictures and the Dyno tune chart, good luck, sounds like a good choice of upgrades.
Too bad, I would have liked to see the results of such modifications!I don't think you Dyno a bike with a gen 3 EJK. It isn't hooked to a computer it is adjusted through the faceplate buttons.
Dyno not required. I may have it done at some point, for Grits and Shins...but I'm in MO I not really sure where to go for Dyno...not a tremendous amount of options that I'm aware of with Victory knowledge. I was told Cycle Works, but I haven't reached out to anyone yet...open to recommendations.I don't think you Dyno a bike with a gen 3 EJK. It isn't hooked to a computer it is adjusted through the faceplate buttons.
This thread is from July 2017. The OP hasn't been on this site since Sept 2017.Hi i have a very similar setup , what are your EJK settings ?
How so?ejk tuner = crap
And those Freedom Performance pipes are also not very good, if we're layin' the cards on the table.all those dobeck style tuners... <snip>... none of them are very good.
