Ok anyone come across this? I saw one guy in another forum had it back in 2014 but cant bump the thread and I dont like the way the forum runs
My '11 cross country has just started doing this, driving me nuts.
Dealer has suggested bad earth somewhere.
The story so far:
I have moved the ignition switch from the cheese wedge to under the seat, been like it for years but once this started decided to have a look at the cable, found some crud in one of the connectors, AhHa I thought, you mongrel (Aussie) cleaned it, reattached it, stil the same.
Havent overly liked the ignition switch way down there so decided to move it up between the handlebars and the inner facing on the righthand side, another story.
When I moved the ignition switch, I cut and soldered the wires under the tank and used duck and bullet connectors near the ignition switch for easy disconnect if I dont like it there, If I do I will make a more permanent connection.
even doing that to the cable, and checked continuity with multimeter, still the same.
Have found and looked at every earth connector in the book, literaly following wiring diagram in shop manual, checked against multimeter, no bad earths.
I do have the Ipod connector with the coolstream duo, again used it for years, unplugged it, no difference.
What is driving me nuts the most is its a bit intermittent ( watching everyone run and hide) in that it will always do it when I turn the key on and then shut off, either bike running or not makes no difference but the intermittent bit is sometimes it will stop after a minute or two while other times will go on for hours (haven't been that interested to watch it for days yet
Any thoughts? besides chucking it out and putting in a custom job
Regards
Wayne
The story so far:
Regards
Wayne
