Cool. Thanks for the info. It is a 100. Sorry about that.'08 should be a 100".... 2008 and 2009 were lower compression and down on power from the 2006/2007 100" engines.
Floorboards and controls from a Kingpin will bolt right up... might need a brake line...Cool. Thanks for the info. It is a 100. Sorry about that.
The only thing I want to add to the Vegas would be to add Floorboards. Don't need to add a kicker on driver side, just flat place to put feet instead of a bar. Any ideas on what would fit that model? I tried to do a few searches and nothing came up. Maybe this is the problem with buying this line is the accessories are not as available, like soemeone previously said. Thanks
Gordon
I have the kuryakin foot boards. They are kind of a short footboard with an open lattice design. I find them perfect for the Vegas. You can change the angle and there are three holes to move them forward or aft of center. Center fits me well. I did add a shim, in the form of a piece of about .063 aluminum to cant the boards slightly up at the outside. You just cut a thin piece and slip it down between the peg and the board where it rotates to fold up. It's just gives your feet a slight outboard edge tip up.Cool. Thanks for the info. It is a 100. Sorry about that.
Gordon
i have a 2009 Vegas, what year Kingpin floor boards would work ?Floorboards and controls from a Kingpin will bolt right up... might need a brake line...
ANYi have a 2009 Vegas, what year Kingpin floor boards would work ?
