06 vegas jackpot oil filter?? | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Vegas' started by Haam Wood 806, Jun 8, 2021 at 6:16 PM.
  1. Haam Wood 806
    Haam Wood 806 New Member
    Tuesday
    4
    4
    06 Victory Vegas Jackpot
    Can't get my oil filter off!!!
    I tried sticking a screw driver through it before I had a filter wrench, now I got a wrench and I can't get purchase on it because there are holes in it.
  2. BP6666VR
    BP6666VR Well-Known Member
    Dec 23, 2013
    3,996
    1,642
    World Citizen
    A stuck oil filter is a difficult issue ... In marine engines this happens sometimes, and you just have to keep at it ... relentless effort ....
    Once the guy destroyed the whole filter before he called me and i got a 225 mm grinding disk wrench and insert that into the base plate holes of the filter, came right off
    angle-grinder-2-pin-spanner-key.jpg da31ed6e-93a4-4de8-9e59-1e146f60713d_1.80a65667bddd41603349f154cb4d30f6.jpeg
  3. Pauljp
    Pauljp Well-Known Member
    Nov 28, 2013
    1,209
    741
    Quebec Canada
    2014 Cross County Tour
    Is there any way the you can use a razor to go around the inside of the rubber o-ring on the filter?
    Remember that it is not the filter threads that are stuck, it is the o-ring against the motor.
    If you can get a razor or knife between it to break that seal then it will spin right off.
    Also, do you have a hose clamp big enough to go around the filter?
    You could tighten one around it then hit the screw part of the clamp on the side with a hammer to turn the filter that way.
    I am thinking the last person who installed the filter didn't oil the o-ring or used a tool to install it. You should only tighten using your hand.
    Hope this helps. Good luck and keep us posted.
  4. Haam Wood 806
    Tuesday
    4
    4
    Thanks guys . I'll give it a shot in the morning and let ya know what happens...
  5. ByteN2it
    ByteN2it Well-Known Member
    Mar 15, 2010
    1,321
    887
    '99 V92C & '09 Vision
    You can get a strap wrench at any auto parts or most hardware store.
  6. BP6666VR
    Dec 23, 2013
    3,996
    1,642
    World Citizen
    Any update mate ?
  7. Gossamer
    Gossamer Well-Known Member
    Oct 13, 2008
    2,902
    460
    Wisconsin
    Victory Cross Country Tour
  8. Haam Wood 806
    Tuesday
    4
    4
    I finally got it off this morning. Wasn't able to locate 225mm disk wrench but I found just the right set of channel locks and was able to get it off. Can't believe how tight it was. Thanks for all the advice fellas
    • Like Like x 4
  9. md2420
    md2420 Well-Known Member
    May 10, 2016
    2,130
    924
    Chandler, AZ
    2014 Vision
    I use one of the rubber strap wrenches for the oil filter. Works well and doesn’t get stuck on the end if off kilter or slip off.
  10. Haam Wood 806
    Tuesday
    4
    4
    Great. Thanks for the tips yall
  11. BP6666VR
    Dec 23, 2013
    3,996
    1,642
    World Citizen
    Congratulations, see told you that it would work, anyway what is a "channel lock " ¿
  12. Chattanooga_Mark
    Dec 25, 2009
    4,795
    2,013
    Chattanooga
    2012 CCT, Wonderful in white
    To others: Be very careful about forcing any metal object between the oil filter rubber o-ring and the engine case sealing surface. The likelihood the o-ring wasn’t oiled is nearly 100%. The likelihood of damaging (scoring) the sealing surface with an external object like a razor blade is very high.
    I’d use a strap wrench or large adjustable pliers long before forcing anything against the sealing surface.
    Glad your pliers worked.
  13. T0ng5
    T0ng5 Member
    May 29, 2020
    57
    26
    Wichita, KS
    2012 Crossroads
    Google for pictures, but they are like plyers but with more than just two slots for adjustably
  14. md2420
    May 10, 2016
    2,130
    924
    Chandler, AZ
    2014 Vision
    also called tongue & groove pliers
    Tongue-and-groove pliers - Wikipedia
  15. BP6666VR
    Dec 23, 2013
    3,996
    1,642
    World Citizen
