Wiring the Vision for a trailer
Discussion in 'Victory Vision' started by ironhead, Jun 13, 2013.
  1. ironhead
    ironhead Member
    Mar 29, 2013
    258
    13
    Cunningham
    2013 Victory Vision
    Okay I am expecting my wiring harness any day now. I have my Vision up on a jack and I still can't see how to run the wires down an under the Vision to the trailer hitch. I have looked up underneath it and the tail lights are enclosed, so I can't run them from there out. Could someone please tell me where their wires are run. Any help would be greatly appreciated.
  2. Fitz
    Fitz Member
    Oct 30, 2011
    81
    4
    St-Hyacinthe
    Victory Vision Tour 2008
    I run my wire by the right side of the seat. I use the wiring diagram from the shop manual. I don't use any electronic device for, only direct connection from the wire to the trailer connector. If you don't have the wiring diagram it is a bit difficult to connect. If you have it, look carefully and all the wire color are easy to find into the wiring of your bike.
    hope this help
    Fitz.
  3. ironhead
    ironhead Member
    Mar 29, 2013
    258
    13
    Cunningham
    2013 Victory Vision
    Thanks for getting back with me. I don't think I will have a problem wiring it, but how did you route the wiring from the trailer hitch up and under the seat. That is what I am trying to find out. I haven't seen an opening anywhere to do that.
  4. Fitz
    Fitz Member
    Oct 30, 2011
    81
    4
    St-Hyacinthe
    Look carefully on the right side, the seat removed, you will see a small route to the bottom of the rear end, I use tie rap (2) to attach the wire to the trailer hicth in the rear wheel well.
    Fitz.
  5. Fitz
    Fitz Member
    Oct 30, 2011
    81
    4
    St-Hyacinthe
    [​IMG][​IMG]
    some pictures takenfrom the installation.
    Fitz.
  6. ironhead
    ironhead Member
    Mar 29, 2013
    258
    13
    Cunningham
    2013 Victory Vision
    Thanks, I guess I have never seen it. I was going to take the tail lights out and just hook everything up there but after getting my bike up on my jack I saw that they were fully enclosed. So I started looking under the seat and saw nothing there. I didn't know what I was going to do. Thanks so much.
  7. ironhead
    ironhead Member
    Mar 29, 2013
    258
    13
    Cunningham
    2013 Victory Vision
    So you didn't use an isolator to get the power from the battery for your trailer lights? And did you not have to have an adapter to go from 5 wire to 4 wire?
  8. ironhead
    ironhead Member
    Mar 29, 2013
    258
    13
    Cunningham
    2013 Victory Vision
  9. Fitz
    Fitz Member
    Oct 30, 2011
    81
    4
    St-Hyacinthe
    The bike original harness I used is under the handle colored plastic plate (right side), if you look at the picture, the harness at left come from the under red plastic plate, and, if you looknear the white wire (it is a part of the trailer harness), you can see the wire loom going down on the far right. I use a 5 pin connectors with no converter, it work perfectly.
    Fitz.
  10. ironhead
    ironhead Member
    Mar 29, 2013
    258
    13
    Cunningham
    2013 Victory Vision
    Well this is very interesting. Am I understanding you to say that there is a harness on the Vision for a trailer already, or is this the wire harness that leads to the tail lights. I have heard about a harness that is prewired for a trailer on the Vision but I have yet to find it on my bike and I have had the seat off several times.
    I hate to sound dumb but you mentioned that you used a 5 pin connector with out an adapter or converter as you said. So tell me how you went down from the 5 wire to the 4 wire pigtail on the trailer. I appreciate all your help.
  11. CncChief
    CncChief New Member
    May 11, 2013
    13
    Vision
    [​IMG][​IMG][​IMG][​IMG]
    I bought the connector and made a plug in wiring harness. I went down the right side of the seat, there is no wiring going thru that side. I use a 5 pin connector thru an isolator in the base of the trunk. In hindsight, I would have made the harness so one end pluged in where it currently is and the other end in the opening further back that you can see in the pic. You can also do the mod to make 4 brake lights always work if you wish by not putting the wires in the two positions required(I believe positions F and G). Positions A,B,C, and D arefor brake, running, left, and right turn(not sure of which is which I used multi meter to figure it out).
  12. ironhead
    ironhead Member
    Mar 29, 2013
    258
    13
    Cunningham
    2013 Victory Vision
    I appreciate this very much. So tell me one thing. Were you able to slide the 4 pin trailer plug down under the right side of the seat and out to the trailer hitch? Or did you have to cut the plug off to get the wires down and then splice the plug back on?
  13. wdwurker
    wdwurker Member
    Aug 26, 2012
    196
    2
    Albany
    2011 Vision Tour
    I recently went through the same frustrations you are experiencing now.
    Some people swearing that their harness had the pigtails already in place for a trailer, others claiming that they didn't use an isolator and still others claiming that you must use an isolator. You got me!
    I ended-up installing an isolator (once wired in I 3M taped it to the front side of the right saddlebag.
    Since my trailer (Lees-ure Lite Excel) uses a five wire plug, I didn't need to convert anything.
    On My Vision... I tapped into the harness running along the right side of the seat, all the wiring you need is right there. I ran the plug wires along the same harness and between the saddlebag and taillight.
    I did this in the winter so the bike was stripped of the seat, trunk, various body panels. I wish I'd had my lift back then, would have made parts of the job much easier.
    What hitch did you go with?
  14. ironhead
    ironhead Member
    Mar 29, 2013
    258
    13
    Cunningham
    2013 Victory Vision
  15. Fitz
    Fitz Member
    Oct 30, 2011
    81
    4
    St-Hyacinthe
    At first, I'm french with some difficulties in english. Sorry if I misleadingyou. I don't have any ready for trailer harness in my Vision. I've had done some welding to connect the trailer harness to the bike harness, I didused heat shrink to isolate all opened wires after welding. I diduse a 5 pin connector, not a 4, and I connected everything without converter. The bike harness can carry the extra load of current asked by the trailer bulb, no problem.
    I used the wire harness page to know the color code of the wire. I had to run the harnessfrom the under rear to thetop because not enough roomfor a connector.
    hope this help
    Fitz.
