WARNING, Serious Safety Issue- Victory Vision
Discussion in 'Victory Vision' started by Thumper, Aug 1, 2012.
  1. Thumper
    Thumper Member
    Jan 31, 2009
    426
    3
    Tacoma
    Yesterday, I was returning to Washington State from a trip thatI made to Arches National Park in southern Utah.I was in Portland Oregon, stuck in stop-in gotraffic, when ICOMPLETELY lostALL steering control of the bike!
    Inordernot to be too dramactic I'll simply describe the parts failure thatLOCKED up thebikes steering. As you know the Vision, basically, has two parts to the front fender. The painted part and the non-painted part that protects the oil cooler and battery box area from rocks and debri. BOTH fork attachmentpointsfor that non-painted part, on my 2008 Vision,cracked, then broke andFAILED.
    That caused this rear portion (non-painted) part of the front fender to move back, towards the engine, thendrop "down" and wedge itselftbetween the battery box holder and the front(chrome) grill. However the two retaining "pushpins" at the top of this fender had loosened but stillhadenough strength to keep it attached. Results? A COMPLETELY LOCKED FRONT STEERING WHEEL!
    Two men pulling separately and together did NOT have enough strength to pull this part out of its wedged position! We layedthebike on it'sside, removed the lower valance and still could not get itout as it (somehow) got hooked upinto the steel battery box.
    Fortunately I have a center stand so weput the bike on the stand and after 5 mins of twistingthe bars and pulling on the fender it finally came loose. I reported this SERIOUS and scary problem to my dealer and Polaris.
    Thenextstep is to notify the NTSB if Polaris does not instruct its dealers or Vision customers to have their bikes inspected for stress cracks of if Polaris does not take action to either strengthen the attachment points or redesign the fender so it can'tlock the steering.
    The cause? I think it was thedays of 100+ degree heat andnormal bike vibration,for hours at a time, that caused thefender mounts to slowly fracture and eventually break on a aging bike. Polaris (probably) knows about the problem because when I ordered the replacment part there was a "manufacturing delay" in receiving it..
  2. satxron
    satxron Well-Known Member
    Jun 19, 2009
    6,680
    1,242
    San Antonio
    2006 Kingpin
    I would hope Polaris is doing a warranty/good will replacement in this area. That part really needs a lab to be looking at the stress. Brakes and steering are the two main ways a bike failure will kill you in the mechanical sense. You found the big one! This is really bad.
    Thank you, for posting it. Everybody needs to be asking these questions now.
  3. BBob
    BBob Well-Known Member
    Aug 18, 2010
    1,587
    103
    Kingman, AZ
    11 XC, 04 KP
    This definitely needs to be reported to the NTSB asap. Not to defame Victory but even their top techs say to report these issues so Ma Vic will act on it.
  4. mjw930
    mjw930 Well-Known Member
    Oct 23, 2009
    3,387
    419
    Ormond Beach
    Octane
    Yes, report it to the NTSB but understand that unless multiple people report the problem and through analysis it's determined to be caused by a defect then and only then will anything be done about it.
    I don't believe I have read about anyone else posting to the various Victory and Vision sites reporting this issue so hopefully it's an isolated incident.
    Of course everyone who owns a Vision should check their fenders for any signs of looseness, cracking or deformation.
  5. SRF2665
    SRF2665 Member
    Jan 14, 2012
    244
    Miamisburg
    V-Star 650 & 2013 XCT co-owner w/Puddlejumper
    Thank the good Lord that it happened when you were stopped. Boy it could have been so much worse. Yes they should replace the parts for free. Definitely make sure it gets reported. It may save someone elses or your own life down the line.
  6. phoenix9
    phoenix9 Well-Known Member
    Mar 28, 2009
    6,136
    81
    Litchfield Park
    2012 Cross Roads Classic Limited Edition #001
    I'm going to hop in line and say REPORT it to the NTSB.....I have posted links to the exact web page here before. As critical as this problem is, I pray that Victory doesn't wait until there are more reported problems. This is not the 1st post on this subject and I'm afraid that if they drag their heels on this one that someone may wind up dead.
    Victory, if you reading this, don't f--- around on this one. One major catastrophe on this problem and there won't be enough money to bring someone back from a hospital bed or a coffin.
  7. aussiejack
    aussiejack Active Member
    Dec 6, 2008
    824
    58
    Ballarat
    Victory Vision Tour Premium
    Which part cracked, the plastic fender or the metal mounting on the fork ? Could a visual inspectionidentify if cracking has started or is disassembly required?
  8. jandjp
    jandjp Well-Known Member
    Apr 14, 2011
    1,149
    216
    Vision
    If I am not mistaken I have read about this ona VMC thread before.
  9. Mudge
    Mudge Member
    Mar 26, 2009
    255
    Glen Ellyn
    It's the plastic that's been cracking mate. From the bolt holes to the edge of the black back half of the fender.
  10. phoenix9
    Mar 28, 2009
    6,136
    81
    Litchfield Park
    Yep, and it's been reported on Vision-riders, and here on the VOG as well. I think it was blown off by a lot of us as an "anomally" or insignificant, but all the sudden we are seeing quite a few of them from the 2008's and 2009's.
    I know from my years working with HDPE (High Density Polyethylene), that there is a "slow crack growth" issue with older resins. In the HDPE industry the resin cell classification for pressure critical applications was changed due to this issue.....but those materials deemmed as not critical will still be using older resin cell classifiaction. The new resin is LIGHT YEARS ahead of the older resin makeup.
    I would never in a million years think of a fender as a "pressure critical" application, but that is proving to be as wrong as can be. THESE are the kinds of things that they cannot see under extreme testing on new models and parts. Real world time and use is the ONLY way these issues are exposed.
  11. Bigfoot
    Bigfoot Well-Known Member
    Sep 27, 2010
    17,759
    2,552
    Northeast Ohio
    2011 Vision
    The rear part of the front fender on Scream is very pliable.
    There is no way that part could resist 2 grown men pulling on it, or at least I would hope not. [​IMG]
    So, Victory must have made a change in the composition of the rear fender part in 2011 or earlier.
    I just went out and checked Scream's rear front fender mounts and all is A-OK.
    Scream has been ridden all over the country in very hot weather for days on end.
    Let's hope that Victory has changed that part in the later editions of the Vision.
    [​IMG]
  12. Trekwolf164
    Trekwolf164 Well-Known Member
    Oct 25, 2008
    4,897
    137
    Washingtonville
    Victory Vision,Slingshot
    I do not know if the fender rear on the front is changed I will have to look at my 2011.
    Thefront fender rearon my 2008 was a very hard dark gray plastic and I was watching it because other Vision-Pilots had had fenders crack or break and mentioned it here and other sites.
    This is the first time I have seen a report of the fender becoming jammed into the oil cooler area of the bike.
  13. Trekwolf164
    Oct 25, 2008
    4,897
    137
    Washingtonville
    Just checked the front fender rear on my 2011 is as Bigfoot described a black flexible plastic more rubber like than rigid like my 2008.
    Do not know what year they changed it but Ma Vic has made a change
  14. Swoop8
    Swoop8 New Member
    Feb 22, 2012
    3
    Aguilar
    2008 Victory Vision
    Thanks for the heads up. Safety is of utmost importance, you don't want to have to be worrying about a potential failure. It definitely needs to be addressed.
  15. Bigfoot
    Sep 27, 2010
    17,759
    2,552
    Northeast Ohio
    2011 Vision
    I just waxed Scream for the first time yesterday, so I kind of thought they had made a change.
    It seems that you have been negligent (thorough cleaning/waxing wise) to your new ride too. [​IMG]
victory vision for serious rider
victory vision ntsb
victory vision safety
