TPS
Discussion in 'Other Victory Models' started by Denny_Pink, Apr 12, 2013.
  1. Denny_Pink
    Denny_Pink Member
    Sep 15, 2012
    80
    10
    Fort Collins
    2008 Victory Vision
    My 2002 V92C runs great, but I am having back fire pops through the mufflers, so the shop said it needs the TPS (throttle position sensor) adjusted. Could someone with an "older" Victory tell me, what does the TPS do, and does it affect fuel mileage or performance? Thank you!
    Denny Pink
  2. ByteN2it
    ByteN2it Active Member
    Mar 15, 2010
    665
    200
    '99 V92C & '09 Vision
    Denny, you can reset the TPS baseline on your freedom engine with the following sequence:
    Key on, switch on, engine off
    Slow 5 count rotate throttle from closed to wide open
    Hold throttle wide open for slow 5 count
    Let throttle SNAP shut/closed
    Cycle kill switch (off then on)
    Start bike, and enjoy the ride
    See if this make any difference. The throttle position sensor is just a rheostat like a light dimmer switch that sends varying degrees of voltage to your ECM. yes it can effect your milage & performance-is it what's causing your backfire issue? Maybe but in my experience backfires on Vics are caused by intake leaks-Check the rubber boot at the throttle body for leaks-you can spray a shot of brake cleaner/starter fluid at the area and if the idle changes you know you have a leak-also check all you exhaust connections and make sure they're tight.
    Here's Loyd'z Tec-talk on backfires
reseting tps 2004 victory vegas
how to tune a tps on 99 victory v92
my victory cross country sputtering
throttle position sensor 1999 victory
v92c dynamic tps reset procedure
v92c throttle sensor
v92c tps
victory cross country tps reset
victory tps reset
victory v92 tps diagoses
victory v92c tps calibration
victory vegas bad tps
