Tips on Removing Baffles from Swept Exhaust?
Discussion in 'Victory Kingpin' started by gfoulke, May 19, 2010.
  1. gfoulke
    gfoulke New Member
    Sep 3, 2009
    66
    I have an 07 KP with Stage 1 swept exhaust. I am toying with the idea of removing the baffles in the pipes (a louder bike is a safer bike). I have a few questions before I dive in that I would love your feedback on:
    Is this a fairly simple procedure (a DIY project)?
    How do I do it?
    Is it reversible?
    Does the EFI have to be flashed after the baffles are removed?
    Thanks in advance for your help on this!
    ~greg
  2. gfoulke
    gfoulke New Member
    Sep 3, 2009
    66
    Has anyone performed any mods to make their KP louder? Maybe removing the baffles isn't the way to go, but what steps have you taken to ensure other drivers notice you?
  3. Sutherland
    Sutherland Well-Known Member
    Aug 23, 2009
    2,482
    89
    Sampsonville
    08 Kingpin/2013 CCT
    How load do you want your bike too be, loud is good within reason. Thelouder the bike the safer the bike is BS, Only the driver can make a safe bike
    Regards
  4. gfoulke
    gfoulke New Member
    Sep 3, 2009
    66
    Thanks for your reply, Sutherland. I want the bike louder because I hear most Harleys coming before I see them and am ready for them, thus they are more noticeable (safer). Being noticeable to other cars is a key to safety on a bike. I am an insurance adjuster and see crashed cruisers as [part of my job about 3-4 times per week. The most common story from riders is "The car turned right in front of me... never knew I was there!"
    My swept pipes have a great sound, but are more quiet than I had hoped. I don't want to rattle the neighborhood, but I would like to be heard if I can't be seen.
  5. Sutherland
    Aug 23, 2009
    2,482
    89
    Sampsonville
    08 Kingpin/2013 CCT
    Don't know about your area but there are a lot of places inposing noise bylaws to discourage this procedure and a lot of place it is illegal to remove baffles Regards
  6. onerider
    onerider New Member
    Dec 6, 2008
    81
    bakersfield
    Well one of mine out fell when bike was new and it sounded likke crap, sort of like a big rig jake brake on decell, and worse on accelleration. Replaced with santa rosa baffles, sounds better and a little louder. Dont recomend running without baffles, new louder pipes are the answer but cost $............
  7. MaddAnthony_59
    MaddAnthony_59 New Member
    May 7, 2012
    34
    Columbus
    Kingpin Touring
    Yes,one of mine fell out last week on the road. I let cool a bit and tossed it in the side bag. Is there a trick to getting them in and having them stay in? My pipe drags on RH turns, so I'm guessing that's why it came out...
  8. BBob
    BBob Well-Known Member
    Aug 18, 2010
    1,579
    86
    Kingman, AZ
    11 XC, 04 KP
    Yes. Just use Loctite on the nut and bolt holding it in. Drill a new hole on the back side if need be.
  9. MaddAnthony_59
    May 7, 2012
    34
    Columbus
    Kingpin Touring
    Got it, Thanks! I replaced the missing bolt with a Hex, and the Nut is welded to the baffle, so the tricky part was getting the baffle back in and lining up the hole.
how to remove baffles from victory swept exhaust
how to remove victory sweep baffle
picture victory swept exhaust baffle
removing baffles from victory exhaust
removing baffles from victory swept pipes
victory swept exhaust baffle removal
victory swept exhaust baffles
