Rear rubber gas tank isolator needed
Discussion in 'Victory Cross Country' started by crosscountryla, Apr 20, 2017.
  1. crosscountryla
    crosscountryla Well-Known Member
    Dec 10, 2013
    3,043
    977
    2014 cross country tour
    Some forum member in the past posted a web link of where to buy a bag of the rubber , rear gas tank, issolators. Could some post this web link again for me.? Lost one on the inside rear of the gas tank. , that fits on the inside of the frame where the bolt slides through to secure the gas tank
  2. Pauljp
    Pauljp Well-Known Member
    Nov 28, 2013
    776
    333
    Quebec Canada
    2014 Cross County Tour
    If you have a hard time finding them you could make a set from a hockey puck.
    Also when you get them, put some GOOP silicon glue on it before you install them so they will always stay in place.
  3. crosscountryla
    Dec 10, 2013
    3,043
    977
    I need some thing in rubber not hard plastic
  4. tree1979
    tree1979 Well-Known Member
    Jan 10, 2014
    2,865
    1,008
    York, PA
    2007 Victory Kingpin
  5. crosscountryla
    Dec 10, 2013
    3,043
    977
    Thanks for that web link. After I pushed my XCT into the garage I used a mini flash light to light up the drive way where I was working on my bike, and then where the grass meets the edge of the drive way, and found the rubber isolator that I was looking for. Happy camper now. :huepfenicon111: I placed an order for four rear , gas tank isolators and the shipping cost was three times the cost of four rubber isolators.
  6. Pelz
    Pelz Active Member
    Feb 9, 2014
    577
    131
    Pine Barrens NJ
    2010 cross roads + 4 others.
    Glue them on, it will save you a lot of stress. Also cut in a connecter on the tank ground wire so you do not have to unbolt it from the tank. Makes removing the tank a 2 minute affair.
    • Useful Useful x 3
