magnum+trunk=no audio
Discussion in 'Victory Magnum' started by 3rdElement, May 7, 2015.
  1. Poseidon
    Poseidon Well-Known Member
    Top Poster Of Month
    Oct 2, 2016
    1,604
    1,431
    Chesterfield, VA
    2016 Magnum
    ^^^^ This
    Here is a link to the amp he is referring to. You could also use an aftermarket amp and V-Twin Audio's plug and play harness.
    Magnum Saddlebag Audio Amp | Victory Motorcycles
  2. Kenstah
    Kenstah theVOG.net Gold Supporter Gold Supporter
    Oct 20, 2015
    675
    341
    Escondido CA
    2015 Victory Ness Magnum
    Exactly what I thought, I was just hoping there was wiring already run from the fairing to the rear in anticipation of installing bag lid speaker systems in all the Magnums out there. But I understand Vic is saving money by not running unnecessary wiring for bikes that might never get additional speakers.
  3. Poseidon
    Top Poster Of Month
    Oct 2, 2016
    1,604
    1,431
    Chesterfield, VA
    2016 Magnum
    There is wiring from the fairing to the back of the bike on Magnums. The plug is under the left side panel below the seat. You will need the wiring from there to the Magnum's rear amp (or an aftermarket amp) then up to the trunk speakers. Let me know if you need me to post a picture of the plug and where it is located.
  4. Kenstah
    Oct 20, 2015
    675
    341
    Escondido CA
    Oooohh!!! I LOVE pictures and it will make it easier for me to show the parts guy at my "dealership"....which I guess is no longer a Vic dealership...sad. but please, pics are helpful!
  5. 3rdElement
    3rdElement Active Member
    Feb 4, 2015
    198
    63
    Castle Rock, Colorado
    2015 Victory Magnum: Magnum Red over Super Steel Gray
    yeah its just the standard xc plug. its even in the same spot.
  6. Poseidon
    Top Poster Of Month
    Oct 2, 2016
    1,604
    1,431
    Chesterfield, VA
    2016 Magnum
  7. Kenstah
    Oct 20, 2015
    675
    341
    Escondido CA
  8. Blackmagnum
    Blackmagnum New Member
    Apr 25, 2015
    7
    Bellingham, Washington
    2015 Magnum
    Yeah I put the trunk on and no speaker but lights and power outlet work fine so I took it to my local dealer where I bought it and they told me I needed to buy the 4 channel amp which is about $400 or I can buy aftermarket for around the same price....Fairing speakers are enough I listen to music with headphones because they also work as ear plugs for those long ride days
  9. Poseidon
    Top Poster Of Month
    Oct 2, 2016
    1,604
    1,431
    Chesterfield, VA
    2016 Magnum
    The audio is not amplified at that connection. It will require either a 4 channel amp up front (V-Twin Audio has the wiring harness if you go that route) or the Victory 2 channel amp that gets mounted under the rear fender to power either the saddlebag lid speakers or the trunk speakers. You could actually do both trunk and saddlebag lids if you find a small 4 channel amp to power all four speakers.
    Here is the 2 channel from Victory. Might be worth a little wait to see if they drop the price on them. Just a thought...
  10. Kenstah
    Oct 20, 2015
    675
    341
    Escondido CA
    You can get 2 and 4 channel bike amps of GREAT quality for far less than $400..I know that's what I will be doing. Maybe a little Rockford Fosgate to power the trunk speakers. PLENTY of boom!
  11. Poseidon
    Top Poster Of Month
    Oct 2, 2016
    1,604
    1,431
    Chesterfield, VA
    2016 Magnum
    I was just throwing all the options out there. I would recommend aftermarket also! I'm installing an Arc Audio system in my magnum right now. 4 channel 600 watt class D amp, 6x9's in the saddlebag lids, and 6.5's up front. Can't wait to get it finished up and hear what it sounds like!!!
difference between victory magnum and cross country
four channel amp for victory magnum
how to change victory trunk speakers
trunk on victory magnum
trunk speakers for victory magnum
victory magnum audio set up
victory magnum with trunk
victory magnum with trunk speakers
victory motorcycles trunk speakers not working
victory trunk no audio
whst clour is victory magnum red
