magnum+trunk=no audio
Discussion in 'Victory Magnum' started by 3rdElement, May 7, 2015.
  1. sgtmorris
    sgtmorris New Member
    Feb 20, 2016
    1
    2015 Magnum
    I added the tour pac to my magnum and as I see here I'm not the first to have an issue with the rear speakers. Adding an amp seems to be the answer but what is the preferred / recommended route? I am satisfied with the stock sound system as I have never had a bike with one before so not looking for anything to loud or fancy, just want the speakers to work. I've spoke with two dealerships who have communicated with Victory and Victory was zero help! Does anyone know if the amp and wiring kit for the lid speakers is a plug and play for the tour pac? I will not always have the tour pac on the bike so I want a quick disconnect for the speakers (stock plug if possible). Any help would be appreciated.
  2. donrich
    donrich New Member
    May 26, 2011
    2
    dallas
    Cross Country
    Would have been nice had they told me about all if this when I bought the bike and trunk... :(. On another subject.... the front 3-way speakers suck... blew them the first month I had them and I don't play volume move than 1/2 way. Very chincy!
  3. Kenstah
    Kenstah Well-Known Member
    Oct 20, 2015
    719
    364
    Escondido CA
    2015 Victory Ness Magnum
    So I've read all the other threads on this issue, have purchased a trunk for my 15 Ness Magnum and am anticipating the trunk speakers not working. Has ANYONE tried grabbing the amp out of a XC or XCT and using THAT since it seems pre wired for the trunk system speakers? Otherwise I'll be buying a 4 channel to replace the 2 channel that came with my bike. Just curious why not one thread has discussed grabbing an amp out of a salvaged XC or XCT and throwing that in...far cheaper and is an OEM option.
  4. NY mike
    NY mike Active Member
    May 15, 2016
    405
    159
    ST john indiana
    Vic magnum harley ultra
    Im in the same boat just put mine on about 3 weeks ago knowing they wouldnt work . Gonna wait till spring throw the ol on go for a ride and if she cant hear it well I will also be looking for a solution. Had a few harley electra glides with front speakers only she could hear it just fine. Ai also have a ultra classic now and she says it does make a difference but she could hear it fine on my others. I hear it fine at 80 mph rollin down the interstate we will see
  5. MRMAXX
    MRMAXX Well-Known Member
    Oct 14, 2013
    1,255
    534
    I think it would be more cost efficient and you would have much better sound it you went with one of the aftermarket single din radio setups.
    Some of the single dins have as much as 200 watts...you "may" not even need an amp with the stock speakers and still get great loud sound.
    The wiring is very simple, and you can still use the factory handle bar controls.
    IMHO...
  6. 3rdElement
    3rdElement Active Member
    Feb 4, 2015
    210
    69
    Castle Rock, Colorado
    2015 Victory Magnum: Magnum Red over Super Steel Gray
    keep in mind the radio/amp is all one unit. and I am not sure the wire harness connector to the amp/radio is the same as the xc or xct. you will also look all bluetooth capabilities of the magnum radio/amp. give it a shot. see how it works and report back!
  7. Alberta_Vegas
    Alberta_Vegas Member
    Jun 22, 2014
    39
    6
    2016 Victory Magnum
    I got the saddlebag amp kit for a good deal but it turns out it is the one for a regular XC, so the wiring is a little different. However I think it will work in my favour because I can still connect the trunk to the harness. I just need to figure out which one is the signal wire for the amp. I will let you know how I make out once I finally get around to installing it.
  8. NY mike
    May 15, 2016
    405
    159
    ST john indiana
    Just out of curiosity when any of you have a passenger on can they hear your stereo
  9. Kenstah
    Oct 20, 2015
    719
    364
    Escondido CA
    So if what you are saying is true and it is all one unit, then I doubt there will be room under the fairing for a second amp, meaning, I will have to install the additional amp in the trunk itself?
  10. 3rdElement
    Feb 4, 2015
    210
    69
    yeah its really just barely enough room for just the amp and the back of the headlight. and usually i have to fully assemble the fairing and then take out the headlight and tweak the angle the amp is sitting. 10k miles though and no issues. so i consider that a win.
  11. Kenstah
    Oct 20, 2015
    719
    364
    Escondido CA
    In addition I need the wiring for the bag speaker set up since there is no wiring run from the fairing back to the trunk area of the bike?
    • Winner Winner x 1
  12. 3rdElement
    Feb 4, 2015
    210
    69
    no. the wiring is all there just like a standard xc or xc tour.
  13. Kenstah
    Oct 20, 2015
    719
    364
    Escondido CA
    Are ya sure? My rep at the dealer doesn't seem to know anything about it. I *assume* the wiring is there since the Magnums are the bikes where they introduced the trunk speakers correct? Makes sense to have the wiring there already. My rep at the dealer seemed to think the wiring harness comes with the amp package. I'm just hoping to NOT have the need for them to open the fairing and run MORE wires from my existing radio all the way to the back with a quick disconnect, to connect to the amp I am already most likely going to have to install in the trunk itself to get the dang speakers to work.
    K
  14. NY mike
    May 15, 2016
    405
    159
    ST john indiana
    @Kenstah the trunk was introduced with the speakers on the cross country tour the problem is the radio in the magnums is 2 Channel and the cross country is a four channel this is why when you plug it in it doesn't work .now I'm not a professional on this but I'm relating to you what everybody with a magnum has related to me because I'm in the same boat
  15. Alberta_Vegas
    Jun 22, 2014
    39
    6
    2016 Victory Magnum
    You are correct the Magnum Amp is only a 2 channel. To add the bag speakers you need to add another amp which mounts under the rear fender. It comes with another wiring harness that has a signal wire running up into the fairing and a left and right bag speaker section. It plugs into the same plug that the trunk would plug into.
difference between victory magnum and cross country
four channel amp for victory magnum
how to change victory trunk speakers
trunk on victory magnum
trunk speakers for victory magnum
victory magnum audio
victory magnum audio set up
victory magnum with trunk
victory magnum with trunk speakers
victory motorcycles trunk speakers not working
victory trunk no audio
whst clour is victory magnum red
