magnum+trunk=no audio
Discussion in 'Victory Magnum' started by 3rdElement, May 7, 2015.
  1. 3rdElement
    3rdElement Active Member
    Feb 4, 2015
    210
    69
    Castle Rock, Colorado
    2015 Victory Magnum: Magnum Red over Super Steel Gray
    All the parts i ordered finally arrived and installed. But the trunk speakers dont work. They adjusted the fade and the balance with no luck. They are ordering a new trunk and also calling polaris tomorrow to see if they missed something. is there anything i need to know that might help them troubleshoot?
  2. P.hunt
    P.hunt Active Member
    Dec 1, 2014
    213
    85
    Roseburg OR
    Victory Vision
    I don't think anyone has put a trunk on a Magnum yet?
    What color did you get?
    Do they make them in our paint colors?
  3. 3rdElement
    Feb 4, 2015
    210
    69
    On the otger victory forum someone has. Yes. The magnum red is sunset red and is an exact match. The ness has a matching red....wouldnt be surprised if the black did too.
    I wonder if the magnum amp os only a two channel amp or if it is a 4 channel? I ask because the saddlebag audio comes with an amp.
  4. 3rdElement
    Feb 4, 2015
    210
    69
    Standard cross country has a menu setting for turning on or off external speakers (aka rear speakers)
    anyone able to check their stereo menu for this setting?
  5. Kaaihn
    Kaaihn Active Member
    Apr 7, 2013
    506
    140
    Orlando
    Victory Cross Country
    The setting for external speakers aren't specific to location speakers. Turning that off means it turns off all speaker output and outputs to bluetooth connected headsets only.
    I'm assuming you did plug in the plug and check for loose wires in both ends behind the left side panel right?
  6. 3rdElement
    Feb 4, 2015
    210
    69
    Yea, connection looks correct and good. Brake light even works.
  7. Shiner
    Shiner Member
    May 18, 2015
    48
    15
    Denver Colorado
    2015 Magnum
    What was the final outcome of no sound on the trunk? Did you need an amp to drive the rear?
  8. 3rdElement
    Feb 4, 2015
    210
    69
    Yeah. Easiest way i found was to install a 4channel rf pbr 300x4 amp and run it in 2ch mode. Fade front to rear doesnt work. But thats not a big deal. If you want fade to work then buy a rear amp only and leave the front system intact.
  9. Todd9905
    Todd9905 Active Member
    Jun 15, 2012
    307
    90
    Central Wisconsin.
    2013 Cross Country Tour
    How bout some pics of your Mag with that trunk??
  10. kevinx
    kevinx Well-Known Member
    Sep 1, 2009
    3,190
    792
    1955 Hyda Glide
    Trunk will not work with stock magnum set up. Vic intentionally removed the capability; because they do not condone use of trunk on a Magnum
  11. P.hunt
    Dec 1, 2014
    213
    85
    Roseburg OR
    Victory Vision
    It does work Kevin it has already been done and you saw my Magnum with the passenger backrest on it.
    Not being a smart ass but what's the difference between a Magnum and a Cross Country Tour that has a 1" lowering kit?
  12. kevinx
    Sep 1, 2009
    3,190
    792
    1955 Hyda Glide
    There is no difference, but their legal department is on task here, and they are covering their ass's.
    Interesting thing. I have 2 customers that moved their trunks to Magnums, and neither got output from the rear.
  13. 3rdElement
    Feb 4, 2015
    210
    69
    completely different audio system, different forks, paint, and front wheel. :) being a smart ass.
    if it was a normal cross country audio system, it would have been easy. but the faux paus was when they changed it from a 4 channel to a 2 channel system.
    and p.hunt will have audio first and mine will follow next weekend. :)
  14. P.hunt
    Dec 1, 2014
    213
    85
    Roseburg OR
    Victory Vision
    That's right Kevin they need the Magnum saddlebag amplifier or an aftermarket amp. I used an Oscilloscope and measured the outputs of the stock Magnum amplifier the front channeled stop making clean power at volume level 22 and is at 14.1volts of output. The rears only measure 480mv output at level 22 so it is only putting out a low level signal to the rear that needs to be amplified
    • Funny Funny x 1
  15. 3rdElement
    Feb 4, 2015
    210
    69
    someone asked for a picture. i'll get a better one tomorrow.
    [​IMG]
    • Like Like x 3
difference between victory magnum and cross country
four channel amp for victory magnum
how to change victory trunk speakers
trunk on victory magnum
trunk speakers for victory magnum
victory magnum audio
victory magnum audio set up
victory magnum with trunk
victory magnum with trunk speakers
victory motorcycles trunk speakers not working
victory trunk no audio
whst clour is victory magnum red
