Lloyd's three cam dynograph comparison
Discussion in 'Victory General Discussion' started by crosscountryla, Apr 20, 2017.
  1. crosscountryla
    crosscountryla Well-Known Member
    Dec 10, 2013
    3,083
    996
    2014 cross country tour
    OK, so here it is... The much anticipated dynograph comparison ofLLOYDZ Motor Workz LSC (blue) VM1-DR (black) and HPT (red) cams
    The bikes represented here are all 106" Victory Cross Country models, with LLOYDZ timing gear @+6, LLOYDZ high flow intake, Vance and Hines exhaust, PCV, and DYNO
    (we have not yet compiled data using 3 of the same steel frame models with the same components)
    [​IMG]
  2. Seminerio
    Seminerio Member
    Jun 12, 2015
    52
    39
    Butler NJ
    I added a 4th line. Stock cams. Xc pcv timing wheel +6 Lloydz filter tuned by Lloyd.
  3. Half_Crazy
    Half_Crazy Well-Known Member
    Aug 23, 2008
    11,874
    4,551
    Great Mills, MD
    2006 Kingpin
    Can't have your cake and eat it too... unless you have lots of cubic inches or forced induction (read: cubic dollars).
  4. bikendad
    bikendad Well-Known Member
    Apr 10, 2009
    4,766
    481
    SE Michigan
    2010 Victory Cross Country
    I like how the LSC gets rid of that low rpm DIP in the torque curve.
    • Agree Agree x 3
  5. Squatch
    Squatch Well-Known Member
    Jan 14, 2013
    3,000
    1,018
    King George VA
    2013 CCT Boardwalk Blue
    Interesting chart Lloyd is showing. This is HPT cams, Hi Flow Lloydz Air filter and D&D wrapped pipes... the only difference between the two in this graph is one is with cats (red) one is without (Blue)... This is pretty close to his LSC cams.... but they are HPT cams....
  6. MRMAXX
    MRMAXX Well-Known Member
    Oct 14, 2013
    1,541
    683
    Here is a good comparison of how the HPT cams respond to exhaust changes. Bike: 2013 XC, HPT cams, Lloydz air cleaner, ECU flash, timing wheel @ 6, PCV and Bassani Road Rage 2>1 exhaust.
    First pull is by Lloydz, exhaust has NO baffle at all, straight thru...
    Second pull is by KMC, only change is baffle installed, but without any sound deadening material .
    I Know...two different dynos on two different days...
    But still nice to see how the baffle effects the results...
  7. P-Dub
    P-Dub Member
    Sep 24, 2016
    71
    45
    Panama City, Florida
    2016 Victory Cross Country
    So more power up top long after the stock cam is out of its range. The stock cam penciled in is all about low end grunt. The LSC looks best to me. The most tq of the 3 down low and up top they are pretty close. I like having as much mid-rang tq as possible. That's where I ride. Good results and I'm looking forward to my XC making power like that one day.
  8. Half_Crazy
    Aug 23, 2008
    11,874
    4,551
    Great Mills, MD
    2006 Kingpin
    Remember... These are examples of full throttle graphs.
    In reality, how often do you whack the throttle wide open at 1800 rpm? This isn't something you're ever going to see/use/do.
    • Agree Agree x 3
  9. Brando
    Brando Active Member
    Jul 17, 2016
    137
    33
    2017 Victory Octane
    It's all about balance since our bikes don't have variable-valve control/timing. I would prefer smoother take-up and more torque in the low-end of the power band since that's where you'll be riding most of the time.
  10. PJRo
    PJRo Well-Known Member
    Mar 31, 2013
    2,392
    1,173
    Pike county , PA.
    2013 Victory Hammer 8-Ball
    The LSC ( Lloydz Signature Cams ) ...were introduced specifically at first for the SC applications......
    Lloydy tried them out in the Baby 106SC motor last May ......
    Peter
  11. MRMAXX
    Oct 14, 2013
    1,541
    683
    On my bike with the HPT cams I am making a 100 lbs tq @ 2500rpm....the same as the signature....so I really haven't lost any low end tq.
  12. catwrench59
    catwrench59 Well-Known Member
    Dec 14, 2013
    1,743
    430
    Lacon
    2012 Victory Cross country tour
    I like how the VM1 has more torque where I ride most. You loose just a touch above 5000 but where a cruiser, touring bike runs most the VM1 is a good choice
  13. notaharley
    notaharley Well-Known Member
    Oct 1, 2012
    2,901
    889
    Effingham, NH
    VISION, BABY!
    See if we can get Oldman47 to put up his dyno sheet for his Vision. Pretty dang good with minimal mods.
  14. jmstang302
    jmstang302 Well-Known Member
    Aug 18, 2013
    883
    345
    Westminster
    2009 Vegas 2008 VISION 2013 XC
    Screenshot_2017-04-12-08-19-07.png Here's my Vision. PC-V, upper filter, wheel @ +4 , and stage1 mufflers.
    @Oldman47 has stock exhaust and veriable intake. I think our graphs are pretty close.
    But this is a thread on X bike cam #s. So not sure how this is relevant.
  15. MRMAXX
    Oct 14, 2013
    1,541
    683
    It dosent...so why post it?
difference between lloydz vm1 cams versus lloydz lsc cams
lloydz lsc cams
